How Is Stopping Distance Related to Speed in Physics?
  • Thread starter Thread starter robandrew06
    Stopping distance
Stopping distance is directly related to speed due to the physics of kinetic energy and friction. As speed increases, the kinetic energy of an object also increases, which in turn requires a longer distance to stop. To calculate stopping distance, one must consider factors such as the mass of the object, its initial speed, and the frictional forces acting on it. The discussion emphasizes the need for specific details about the coursework and prior knowledge to provide effective assistance. Understanding these principles is crucial for completing the coursework successfully.
robandrew06
Hi,our teacher has just given us piece of coursework like two weeks before exams. This piece seems hadrer than the iothers and i really need some help!
For the krux of it I need to know the physics behind stopping distance being related to speed. Can anyone offer some help?
Welcome to PF, robandrew. Please note that, for homework and coursework questions, you are required to show your work before we can help you. However in this case, since you are not exactly asking for homework help, it would suffice to mention some further details regarding what level you are studying, what prior knowledge you have for this topic, or any other information that you can.
I could, for example, give you some websites (like hyperphysics http://hyperphysics.phy-astr.gsu.edu/HBASE/crstp.html) but I don't know whether they would help.
Finally, I've moved this to intro physics HW forums, where it belongs.
Hi, I am currently doing AS level data analysis course work.
I have a link of the work I have done so far, but I basically need to know how to work out stopping distance of a trolley released from a slop.e If I know the mass of trolley, and the kinetic energy and speed etc how do ui workl out the stopping distance?
thankyou!
I don't see any graphs in there that you have a slope from which to calculate anything. Could you shed some light on this?
There were two threads started in General Physics, so I have merged them here.
Shows how bad my memory is: I can't even remember two days ago!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
