How Is the Retarding Torque Calculated in a Rotating System with Friction?
  • Thread starter Thread starter fiziksfun
    Rotational
The discussion focuses on calculating the retarding torque in a rotating system with friction, specifically involving a thin steel rod with attached balls. The system consists of a rod of mass 6.4 kg and length 1.2 m, rotating at an initial angular velocity of 30 revolutions per second, which converts to 188.4 rad/s. The angular acceleration is determined to be -5.89 rad/s², leading to the conclusion that the net torque can be calculated using the formula torque = I * angular acceleration, where I is the moment of inertia of the entire system, including the rod and the attached balls.
  • Understanding of angular velocity and its conversion to radians per second
  • Knowledge of angular acceleration and its calculation
  • Familiarity with the moment of inertia and its formulas for composite systems
  • Basic principles of torque and its relationship with angular motion
  • Study the calculation of moment of inertia for composite bodies
  • Learn about the effects of friction on rotational motion
  • Explore the relationship between torque and angular acceleration in rotating systems
  • Investigate real-world applications of retarding torque in mechanical systems
Mechanical engineers, physics students, and anyone involved in the analysis of rotational dynamics and friction in mechanical systems will benefit from this discussion.
fiziksfun
1. "A small ball of mass 1.06 is attached to each end of a thin steel rod of length 1.2 m and mass 6.4kg. The rod is constrained to rotate in the horizontal plane about a vertical axis through its midpoint. At some instant, it is observed to rotate with an angular velocity of 30 rev / s. Due to friction, it comes to rest 32 seconds later. Assuming a constant frictional torque, compute
the retarding torque exerted by friction.
2.
First I converted the initial angular velocity to rad/s which is 188.4 rad/s
I computed the angular acceleration to be -5.89 rad/s2
we know the final angular velocity is 0
I THOUGHT i could do
torque,net = I*angular acceleration
and assume that friction is the only torque that's making it slow down ??
I'm so confused..
I think I is (1/3)M,rod*L^2
any help or suggestions would be greatly appreciated.
I is not that, since a ball is attached to the end, I,total would be I of the rod plus M(ball)(L/2)^2
hope it helps
  • · Replies 19 ·
  • · Replies 60 ·
  • · Replies 71 ·
