How is the square of a transformed vector not a vector?
  • Context: Undergrad
  • Thread starter Thread starter BHL 20
    Square Vector
The discussion centers around the nature of transformed vectors and the implications of squaring their components. Participants explore whether the squared components of a transformed vector can still be considered a vector, particularly in the context of linear transformations and coordinate systems.
  • Some participants assert that the squared components of a transformed vector do not constitute a vector because they do not transform back to the original vector under coordinate transformations.
  • Others argue that the squared components can still be viewed as a vector, but they do not result from a linear transformation of the original vector.
  • A participant highlights the importance of defining a vector in terms of its transformation properties across different coordinate systems, emphasizing that a vector must maintain a specific relationship between its components in various systems.
  • Another participant discusses the function that relates different bases in vector spaces and how this relates to the transformation of vectors, noting that the squared components do not adhere to the expected transformation laws.
  • There is a mention of the term "contravariant" in relation to the transformation of vectors, indicating a deeper exploration of the mathematical framework involved.
Participants generally disagree on whether the squared components of a transformed vector can be considered a vector. Multiple competing views remain regarding the definitions and properties of vectors in different coordinate systems.
The discussion reveals limitations in the definitions and assumptions regarding what constitutes a vector, particularly in relation to transformations and the implications of squaring components. There is also a lack of consensus on the specific mathematical properties that must be satisfied for an entity to be classified as a vector.
BHL 20
So I learned that if a vector (a1, a2, a3) is transformed to a different set of coordinates, and the components of the resulting vector are squared like so: (a1'2, a2'2, a3'2), this result is not itself a vector. The proof for this simply shows that each component ai'2 does not transform to ai2 when brought to the original coordinates.
I'm having a lot of trouble understanding this. Say the vector (1,0,0) is transformed by a 90O rotation about the z-axis. It becomes (0,-1,0). The "square" of this is (0,1,0). Sure this doesn't transform back to (1,0,0) but if this triplet is considered in isolation, without any reference to the original vector, there doesn't seem to be any reason not to consider it a vector.
(a1'2, a2'2, a3'2) is of course a vector. It is simply not a result of a linear transformation of (a1', a2', a3')
It is correct to say that the map [itex]f: (a_0,\ldots,a_n)\rightarrow(a'_0,\ldots,a'_n)[/itex] maps vectors to vectors. The author's point appears to be that, given a linear map [itex]S[/itex], [itex]S f S^{-1}\neq f[/itex] in general. This is true precisely when [itex]f[/itex] is non-injective.
Where did you learn this? It may be that there is some context missing here.
Or maybe you mean that somehow the transformation is not tensorial in some sense?
It's from a vectors and tensors course. It was an example used to illustrate the definition of a vector.
And, what, exactly, is the definition of "vector"? It is NOT simply "three numbers"! The same vector
in different coordinate systems may have different "components". In order to be a vector, there must be a specific homogeneous relation between the components in one coordinate system and the components in another.
(The point of "homogeneous" is that a vector that has all components 0 in one coordinate system has all components 0 in any
coordinate system (the "0 vector"). From that, it follows that if U= V in one coordinate system, then U- V= 0 in that coordinate system so U- V= 0 in any coordinate system so U= V in any coordinate system. The result of that is that if an equation involving only vectors (and their extension, tensors) is true in one coordinate system, then it is true in any coordinate system.)
When books like this use the term "vector", they're not referring to an element of a vector space, or even a triple of numbers. They're referring to a function that associates a triple of real numbers with each ordered basis for ##\mathbb R^3## that can be obtained by applying some rotation R to the components of the standard ordered basis.
The authors never say that for some reason. I don't know if they think it's so obvious that it's not worth mentioning, or if they just don't have a clue what they're doing.
The function is such that the relationship between two triples associated with two different ordered bases is given by the tensor transformation law.
Suppose that the relationship between new (=primed) and old (=unprimed) basis vectors is given by
$$e_i' =Re_i = (Re_i)_j e_j =R_{ji} e_j.$$ Let x be a triple associated with the "unprimed" ordered basis, and let x' be the corresponding triple associated with the "primed" ordered basis. We have
$$x_j e_j =x_ie_i =x_i'e_i' =x_i' R_{ji} e_j$$ Since a basis is linearly independent, this implies that
$$x_j= R_{ji}x_i' = (Rx)'_j$$ and therefore
$$x=Rx'$$ and
$$x'=R^{-1}x.$$ The term "contravariant" is used because of the appearence of ##R^{-1}## instead of ##R## in this equation.
The claim in post #1 is saying that we shouldn't expect ##(x_i')^2=R_{ji} (x_j)^2## to hold just because ##x_i'=R_{ji}x_j## holds.
In the context of tensors, the term "vector" usually does not just refer to a mathematical triple (x, y, z) of numbers. A "vector" must be defined in such a way that it converts to other coordinate systems in the correct way. That definition of "vector" makes it an entity that is independent of the choice of coordinate systems. (It is an equivalence class of triples with their associated coordinate system). That allows it to represent a physical entity that exists even if no one is around to specify a coordinate system to measure it in. Your (a1'2, a2'2, a3'2) will not undergo coordinate system transformations correctly. .
  • · Replies 16 ·
  • · Replies 50 ·
  • · Replies 0 ·
