How is the thermal conductivity affected by magnetic field?
The discussion centers on the relationship between magnetic fields and the thermal conductivity of metals, particularly steel. Participants highlight that while there is no established connection in materials physics, concepts such as magnetothermoconductance and spintronics may suggest potential interactions. Key references include a 1992 paper on magnetothermoconductance and discussions on the Hall effect and magnetoresistance. Overall, the consensus is that any effect of magnetic fields on thermal conductivity is likely to be minimal and not widely recognized in current research.
  • Understanding of thermal conductivity principles in metals
  • Familiarity with magnetoresistance and the Hall effect
  • Knowledge of spintronics and its implications in materials science
  • Basic grasp of phonon mechanisms in thermal and electrical conductivity
  • Research "magnetothermoconductance" and its implications in materials science
  • Explore the "Hall effect" and its relationship with thermal conductivity
  • Investigate "spintronics" and its potential effects on thermal properties
  • Review the paper "THERMAL CONDUCTIVITY OF ALUMINUM, COPPER, IRON, AND TUNGSTEN" for empirical data
Researchers, physicists, and materials scientists interested in the interplay between magnetic fields and thermal properties of metals, particularly in advanced materials applications.
Seyit KAPLAN
Hello,
I'm searching for how magnetic field affects the thermal conductivity of the metal (such as steel in solid form). If someone suggests any article about it will be very helpful.
Why should it?
Vanadium 50 said:
Why should it?
If it doesn't, also why?
Welcome to PF Seyit. :welcome:
Why? Because they are not connected. That's not a very good question.
If such an effect exists, it is certainly not a standard part of materials physics. You could perhaps handwave an argument for it that electrical and thermal conductivity are related through phonon mechanisms, and electrical magnetoresistance is a thing, so perhaps thermal magnetoconductance is a thing? There is also the concept of spintronics and spinon conductance, where there might be something analogous to phonon heat transfer for spinons.
I surmised that such a phonemonon could be called magnetothermoconductance, and found one paper on it from 1992: http://jetp.ac.ru/cgi-bin/dn/e_074_03_0574.pdf It may also be mentioned in this paper, which I don't have access to right now: https://www.worldscientific.com/doi/abs/10.1142/9789812701879_0029 There was also one hit for magnetothermoresistance, where I just have the title: Thermoelectric properties and negative magnetothermoresistance effect in Te wires
Refining my search a bit to look at spintronics, I found this paper (and others) talking about magnetocalorimetrics, the relationship between magnetic and thermal effects: https://arxiv.org/pdf/1107.4395.pdf (arxiv because free, search for peer reviewed if you want). That paper has descriptions of the magnetic Pelletier effect, magnetic Seebeck effect, thermal Hall effect, which I think are up your alley.
So I guess to answer your question, it's conceivable that such an effect exists, but it's fairly obscure. The more serious treatment of spintronics is fairly new, so maybe give it a few years or decades.
I suppose it might, since it can affect the electrical conductivity. You could also probably fabricate materials that did have a connection between applied magnetic field and thermal conductivity, similar to how liquid crystals can be used to alter the optical properties of a material when an external electric field is applied.
Maybe start here and follow some of the references and add Google search terms to see where it takes you:
https://en.wikipedia.org/wiki/Magnetoresistance
BTW, is this question for a schoolwork assignment? It kind of sounds like one...
To the OP: google " thermal conductivity and magnetic properties in metals" and then ask questions as necessary. You can also substitute "ferromagnetic metals".
The effects are likely not very large.
Thanks for your kind and detailed reply, I already read some of these articles, but I couldn't find enough explanations.
First of all thanks for your reply, I'm studying on my PhD thesis, it is not directly relevant my subject, but i am quiete interested in physic. I already checked on wikipedia and followed all steps. You wrote that it can affect the electrical conductivity, can you explain how? Because i think it is quiete similar behavior to thermal conductivity.
Not sure about that. As the effect isn't discussed much, it would be very slight / negligible and these days, devices are designed to make use of almost any significant effect you could think of. I was thinking about the Hall effect, which would be related to 'effective' electrical conductance of a length of semiconductor - by deflecting electron flow. In substances where thermal conductivity is via electrons, the electrons would have longer curved paths (old model of course). Couldn't that affect thermal conductivity?
Can you say what field your PhD is in and what your background is in math and physics? That will help to guide how we frame our answers.
I got to the Magnetoresistance page via the Hall Effect page, since the Hall Effect in semiconductors is a pretty well-known effect, and seemed like it could be related to a change in resistance (because of current bunching). Have you read the Wikipedia article that I linked to? If so, can you ask specific questions about their description that is not making sense to you? Thanks.
If there is a change in the resistance, a reconstruction of the Fermi surface, or a change in electron scattering then there will be some change in the thermal conductivity because electrons are one of the carriers of energy in metals. Magnetic fields applied to metals can do all those things. The question is: how big is the effect? In most cases, I think the effect will be a tiny fraction of the overall thermal conductivity.
You are asking about steel. Could you be more specific about the situation you are thinking about, especially the expected temperature range and the degree of magnetization or applied field?
