PhysicsPete2564
- Messages
- 2
- Reaction score
- 0
In the figure below (image attached) a constant force of 82N is applied to a 3kg box at an angle of 53 degrees causing the box to move up a frictionless ramp. How much is work is done by that force (Fa) when the box has moved through a vertical distance of .15m?
Work = Force X distance
I thought this would be a simple problem. Work equals force X distance so I thought you would just multiply the force and distance vectors. Multiplying the vectors means using the dot product. So initially I just did:
W = (82N)*(.15m)*(Cos(53)). This equals 7.40 which is not the correct answer.
I found a problem similar to this on the web and apparently the way to do this problem is W = m*g*distance. This produces the right answer for the problem (4.41) but I don't understand the logic behind that equation. I thought since the force and distance are NOT equal in direction you need to multiply vectors. What am I missing here?
Thank you,
Allen
