How long can a 1.5 V battery light a flashlight bulb drawing 0.6A?
A 1.5 V battery with 4.3 kJ of energy can power a flashlight bulb drawing 0.6 A. To determine how long it can light the bulb, the power consumed by the bulb must be calculated using the formula P = IV, which gives a power of 0.9 W. Since power is measured in Joules per second, the total energy in Joules (4,300 J) can be divided by the power (0.9 W) to find the time in seconds. Converting this time into hours provides the final answer. Understanding the relationship between voltage, current, and power is crucial for solving this problem.
Sarliz
You'll have to forgive me... I've got some rather poor Physics books with which to consult, so this may seem rather simple. I think I understand the concepts but I don't think I have all of the information from my sources to answer this problem.
A 1.5 V battery stores 4.3 kJ of energy. How long can it light a flashlight bulb that draws 0.6A?
Units should be in hours, but I'm not sure what to do with only having equations V = IR and I = E/R (where E is epsilon, of course). I don't know what part of this factors into time!
The electric power in a DC circuit is P =IV. Is that enough to get you going?
Guess it'll have to be. Thanks.
If you have more questions I'll be happy to clarify :smile:
The units of power are of course Joules/second. That is where the time comes into it.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
