How Many Electrons Pass Through a Gold Wire Per Second?
7 replies · 10K views
victorializ
The resistivity of gold is 2.44 x 10-8 Ω m at a temperature of 20°C. A gold wire, 0.5 mm in diameter and 44 cm long, carries a current of 380 ma. The number of electrons per second passing a given cross section of the wire, is closest to:
A) 2.4 × 10^18
B) 1.2 × 10^22
C) 2.8 × 10^14
D) 2.4 × 10^17
E) 6.3 × 10^15
R=ρL/A
R=(2.44 x 10^-8) (.44)/∏(.00025^2)
R= .0547
then i multiplied the resistance by the current (.38) to get .021 for a voltage.
then i divided that by (1.6 x 10^-19) and got 1.3 x 10^17 which isn't right but is close to the answer which is A
Why did you divide a voltage by the electron charge? Do you expect the right unit "per second" as result of that calculation?
You are given the current. What does a current of 1 A (example value) mean?
A) 2.4 × 10^18
B) 1.2 × 10^22
C) 2.8 × 10^14
D) 2.4 × 10^17
E) 6.3 × 10^15
R=ρL/A
R= .0547
Something's off by a factor of 18.5 and you call that 'close'?
Learn that people are going to give you problems with a lot of irrelevant information!
so i need to use the fact that 6.241 x 10^18 electrons/sec pass through a circuit which is 1 A
when i use that number though i still have it wrong so I'm not really sure where else my calculations are messed up.
But the current isn't 1 A.
oh my goodness so most of the information in this problem is irrelevant? all i need is to do a proportion between 1A and the 38 mA in the problem?
If that gets you closer to the right answer, go for it! :smile:
380 mA would be even better ... :wink:
Yes (apart from the typo (?) NascentOxygen pointed out).
