How many Newton-Raphson iterations needed for 5 decimal places?
  • Level: Undergrad
  • Thread starter Thread starter jvignacio
2 replies · 3K views · last reply
jvignacio
when it asks to find the largest solution to 5 decimals, what's the initial value i start with for Xo and how many iterations should i do?
thank you
Start with a reasonable guess, iterate until you reach the desired precision.
Compare each iterate with the previous, when the difference is small enough you are done.
One word of caution: Although Newtons method normally converges very fast, there is no guarantee that it will converge at all ! If you see the difference getting bigger instead of smaller (or some sort of oscillation), you know that Newton is running amok. Try to guess a new initial value and start again.
If you have written a little program to do the job (and you should do so, doing this stuff manually is boring), the easiest solution to the non-convergence problem is to count the number of iterations. If you are not done after, say, 30 iterations, stop the program and ask the user for a new initial value.
