How many numbers can you make with four 4s?
  • Level: High School
  • Thread starter Thread starter Greg Bernhardt
    Puzzle
36 replies · 8K views
Say you've got four 4s -- 4, 4, 4, 4 -- and you're allowed to place any normal math symbols around them. How many different numbers can you make? It's best to think of a number and then try to make it.
The origination of the puzzle and some examples are in this video
Mathematics news on Phys.org
##4444\int dx =4444x +C## I think that about covers it. o:)
Imagine what you could do with seven fours?
You could order Pizza Hut pizza! (From an old pizza commercial)
Nice video. I was waiting for Knuth arrow notation to come in but it never did.
I think that wraps things up!
No, it doesn't. How do represent the number 10 for example?
I think the log based proof was quite good for numberphile.
Also it seems you are allowed to put the minus sign in front of the log function which would extend the combos into the negative numbers for reals
0 could also be done with something log based like
lg(4/4)=0
Greg Bernhardt said:
Can anyone figure out Pi?
I'm not quite certain if this is allowed by the problem such as using variable x, such as using standard symbols and four 4s as numbers...
But Pi can be gotten in certain ways
##lim_{x-> -1^{+}} =cos^{-1}(x)##
I'm not sure if cos^{-1} was defined exactluy at the value of (-1)
so that might be something like cos^{-4/4}(-4/4)= pi
But limit should still exist. I suck at trig.
that is in radians of course
This is indefinite integral, i.e. function ...
For any real number x: x = C/4444 . Just pick a C = x•4444 ...
Or x = C/(4+4+4+4), or x = C/(4•4•4•4) ...
or even (different form) x = C(4444) [C=x/4444], etc., or use other operations or operators ...
Thus trivial, unless you put more constraints in the problem.
It wasn't meant to be taken seriously.
As for ten, x = 0, C = 10. There you go.
Assigning variables is kind of cheating :D
$$\pi = \sqrt{4}~ \arccos (\sqrt{4\cdot 4}-4) = \arccos \left(4-4-\frac 4 4 \right)$$
Similar expressions exist with the arcsine.
$$e=\exp\left(4-4+\frac 4 4 \right)$$
Well...
It would appear so (and mine above could also be considered partially humour), but isn't solving an equation like inverting an operator or a function? Thus cosistent with:
And it is not limited by the video, or the original post [but since the OP sais now so we can now perhaps put it as a restriction ... (?)].
For example (aside/[or plus] the fact that functions can be considered as operarors, and operators are essentially functions):
If x is any real number (say π), and f any invertable real function (to avoid regular or perplexity form plain equations), and it happens that a number A which is directly/easily or else consructed by the 4 4s (say 4444) is related to x as A = f(x), then x = f-1(A)
[e.g. x (or e.g. π) = f-1(4444), and that's true for any [invertable] function f (providing it satisfies A = f(x) ) (e.g. a•x, sin, cos, exp, ln, log etc.) - just pick an appropriate one and be my guest! ...]
That's what I essentially did above, e.g.
Stavros Kiri said:
x = C(4444)
where f(x) = (1/C)•x, A = 4444, and mfb did essentially the same with cos and arccos
mfb said:
π=√4 arccos(√4⋅4−4)=arccos(4−4−44)​
since arccos = cos-1 ...
So are we joking or serious? I am a bit confused.
My opinion is that the problem on the video etc. is either trivial or one would have to put explicitly more restrictions, namely to the basic functions and operations only, with no arbitrary constants (other than the 4 4s and their obvious basic step derivatives).
[In other words functions e.g. like a•x, or a•cosx ... are not allowed, unless a=1 ... etc., otherwise one can do anything - it's trivial]
So the problem is not the variables but the arbitrary constants.
mfb said:
I used common mathematical functions.
I didn't have to make up a function just for this exercise.
I know. Your's is ok
As long as the OP accepts inverse functions.
Mine has arbitrary constants, so may be not allowed, but the restrictions should be made explicit.
There is nothing inverse about it. The arccosine is a regular function (in more than one way). The cosine (restricted to [0,pi]) is the inverse function of the arccosine. And now?
But one has to define explicitly which functions are allowed to build from, and if inversing is allowed. (+see my edited posts above about arbitrariness of constants) But in any case I think your's is ok. I just wasn't sure if you were serious or not.
Well...
Trying to come up with a simple way to get closer...
Using factorial's and decimals you can get approximately close:
$$\sum_{n=1}^{n=4} .4! = 3.54905... $$
What about...
$$ .04! \times 4 - .4 -.4 = 3.113752 $$
What about...
A) You can just use the "Decimal Point Approximation Sequence", if you are familiar with it. You can get as close as you want [to any real (rational or irrational) number] ...
The formula is xn = [10nx]/10n, where [ ] notation is the "Integral Part" of a real number (e.g. [8.3] = 8, [11.9] = 11 , etc. ...), and xn is the n th order approximation (of x).
But any such approximations are not acceptable solutions here, I think, unless you use somehow the fact that limn→∞xn = x, and somehow involve the 4 4s ...
B) But I think there is also something wrong with your notation and/or understanding of sums and factorials ... (etc.)
[e.g. what is ".4!" ? ... . And the sum needs iteration index ...]
This avoids .04, but introduces logs, which I didn't want to do...
$$\log(\log((4!)!^{4!} \times .4)) +.4 = 3.156352..$$
This is a better use of log maybe, base 4!
$$log_4(44) +.4 = 3.12927...$$
Okay, I'm done. :smile:
Whats wrong with it? .4! is a gamma function. My sum reads... .4! + .4! + .4! + .4!. or .4!(4).
This is a correct notation (no factorials on a decimal, only for integers/naturals - unless you use advanced calculus ...), I haven't checked the result though, but still approximation, not full answer ...
Interesting as inventions though, that you get so close ...
Ok, I didn't know you knew advanced calculus, but still the sum could be fixed, as a notation. (e.g. ∑xi , and defining the limits of i on the sum ...) [unless you just want to say 4 times (.4!) , in this case, or give the explicit sum, as you mentioned ..]
If you allow both factorials (as extended using the gamma function) and square roots it should be possible to get arbitrarily close to ##\pi## or any other positive real number by simply applying both operations a large number of times in an appropriately interleaved pattern such as:
##\sqrt{\sqrt{\sqrt{\frac{4+4+4}{4}!}!}}!##
Edit: while this approach will (I think) directly give you an approximation for any x > 1, one would need to apply a minor manipulation to get approximations for 0 < x < 1.
But back on track with the exact solution (not approximation), for any real number x (e.g. π) [integer, rational, or irrational ...].
Another, perhaps better, and more direct way (than what I attempted earlier above etc. - e.g. see/cf. post #15) is to in fact begin with the actual question: x = f(A), where A is [the only constant allowed (?), besides the 4s themselves and their as stated (in the problem) derivative numbers...] a number like 4444, 4+4+4+4, and the like, as stated in the problem ..., and f an appropriate real function or operator, or combination or sequence of operations (etc.).
x = f(A) is also already the answer, as well as the method of construction, by choosing f appropriately, but the restrictions on the functions and operations (etc.) must be made explicit and clear, otherwise there are plenty of choices for f (and the problem becomes easy and trivial), if one allows arbitrariness of constants and functions [as well as inverting] (etc.). [See/cf. my other posts #15, #17, #19 (as well as #10) earlier above ...] (mainly for the restrictions)
PAllen said:
Let x=0, C=10
This way you use four 4's, a 0 and a 10. The problem says only four 4's.
But 0 and 10 can be expressed primatively in terms of 4 4s (see the video etc.), so I think it is allowed. But arbitrary constants C, A .. etc. aren't ... , if Greg has agreed on this (etc.) ...
Both at the same time with a total of 4 4s? Yes they can be expressed like that, but then there is no point in introducing integrals and whatever because you have expressed 10 via 4s already.
