Calculating Cable Turns for a Job
  • Thread starter Thread starter Brian82784
    Cable Diameter
To determine how many turns of cable to remove from a 60-inch diameter reel for a job requiring 314 feet of cable, the circumference of the reel is calculated to be approximately 188.5 inches. Converting this to feet gives a circumference of about 15.7 feet. To find the number of turns, divide the total cable needed (314 feet) by the circumference (15.7 feet), resulting in approximately 20 turns. Carrying units throughout the calculations is emphasized to avoid errors and improve clarity. The calculations confirm that 20 turns will yield the required length of cable.
Brian82784
Hello,
I'm trying to help my kiddo with some math, and unfortunately this is stumping me.
A full reel of cable has a diameter of 60 inches. A job requires 314 feet of cable. How many turns of cable should be taken off the the reel?
The answer is 20 turns, but I can't seem to figure out how to get to that answer.
60 inches = 5ft
60 diameter = 188.5 circumference
Welcome to PF.
Our schoolwork rules require that you show as much work as you can on schoolwork questions. If the wire removed from the spool all has the same diameter, how many circumferences (turns) does it take to add up to 314 feet?
One hint that I think we can already give is that it looks like the 314 ft is designed to cancel out something. So it might not be good to multiply out the 60*3.14 = 188.4. Let things cancel.
5 * 3.14 = 15.70
15.70 * 20 =314
Brian82784 said:
5 * 3.14 = 15.70
15.70 * 20 =314
It's good technique to carry units along in your calculations. It helps you avoid mistakes, and helps us understand what you are doing. :wink:
Likes scottdave and FactChecker
The units above are inches -- you are asked to find how many turns to make 314 feet. By happy coincidence, 314 feet is approximately equal to 100##\pi##.
+1
Likes PhDeezNutz and jim mcnamara
The working out suggests first equating ## \sqrt{i} = x + iy ## and suggests that squaring and equating real and imaginary parts of both sides results in ## \sqrt{i} = \pm (1+i)/ \sqrt{2} ## Squaring both sides results in: $$ i = (x + iy)^2 $$ $$ i = x^2 + 2ixy -y^2 $$ equating real parts gives $$ x^2 - y^2 = 0 $$ $$ (x+y)(x-y) = 0 $$ $$ x = \pm y $$ equating imaginary parts gives: $$ i = 2ixy $$ $$ 2xy = 1 $$ I'm not really sure how to proceed from here.
  • · Replies 24 ·
9K
