How might determinism affect probability?
  • Level: High School
  • Thread starter Thread starter cliffhanley203
    Determinism Probability
69 replies · 8K views · last reply
You have to be careful with stuff like this. For example, if x is a standard normal random variable, then whatever value you obtain from sampling x, the probability of getting exactly that value was 0. So p=0 doesn't necessarily mean that it cannot happen.
cliffhanley203 said:
Wouldn’t the P of it not happening be zero if it literally cannot not happen – which means it must happen)?
You have a fundamental misunderstanding. "Probability" is a number associated with a set. If E is a set, P(E compliment) = 1 - P(E). If P(E) = 1 then P(E compliment) = 0.
The mathematical probability of an event has no definite connection with the non-mathematical concepts of "happening" or "not happening".Having said that, the usual way to formulate a probability model model for a real life problem is to assign higher probabilities to events that "happen" more frequently. The usual way to interpret the set E compliment is that it represents the event that the things in set E did not happen.
Q. Is the following random variable a ‘standard normal random variable’;
X = {0,1,3...all the way to 36) [with reference to a European roulette wheel] [and the numbers in the brackets being the sample space]?
Q. Re ‘...whatever value you obtain from sampling x...’ ; do you mean spinning the wheel several times and collecting some data? Or does 'sampling' mean putting the possible outcomes in brackets as I've done above?
P.S. Thanks for your patience.
No, a standard normal random variable has a normal (bell shaped curve) distribution with mean 0 and standard deviation 1. It is a continuous distribution, not a discrete one like a roulette wheel.
Yes
“You have a fundamental misunderstanding. "Probability" is a number associated with a set. If E is a set, P(E compliment) = 1 - P(E). If P(E) = 1 then P(E compliment) = 0.”
Where is my fundamental misunderstanding? Complement means, in the above example, ‘not E’, or, not the event/set in question, or, to quote Mathsisfun, “...the Complement of an event is all the other outcomes (not the ones we want). "
Just to check that I have got it, I’ll apply it to my example of the P of red on a European roulette table where red is determined (in a determinstic world).
The set, call it R (for red), is the all of the red numbers on the wheel. So R = {1,3,5,7,9, etc}
The complement of R is all the numbers that are not R (that is black and green), or, R’. So, R’ = {0,2,4,6,8,10,etc}.
And, to lay it out as you have above;
If R is a set, P(R complement) = 1 – P(R). If P(R) = 1 then
P (R complement) = 0.
So, using the classical interpretation, in a indeterminstic world;
P(R) = 18/37. P(R complement) = 1-18/37 = 19/37.
And, finally, using the classical interpretation in a deterministic world;
P(R)= 1. P (R complement) + 1-1 = 0.
“The mathematical probability of an event has no definite connection with the non-mathematical concepts of "happening" or "not happening".”
Q. What do you mean by no “definite” connection?
Q. What connection does it have with those concepts?
“Having said that, the usual way to formulate a probability model for a real life problem is to assign higher probabilities to events that "happen" more frequently. The usual way to interpret the set E compliment is that it represents the event that the things in set E did not happen.”
Yes.
In this context, it is worth thinking about @Dale 's post #31. Suppose that a number has been selected from a continuous distribution. Then something has happened. Call that selected number r. Then r has "happened" but its probability is 0. That exact number, r, will never happen again.
FactChecker said:
In this context, it is worth thinking about @Dale 's post #31. Suppose that a number has been selected from a continuous distribution. Then something has happened. Call that selected number r. Then r has "happened" but its probability is 0. That exect number, r, will never happen again.
Also, the complement of r has probability 1.
Yes, your example corrects this statement.
Assigning an event a probability does not permit us to make statements about the event happening or not happening unless those statements also speak of probabilities. If we say Pr( "The probability the coin lands heads") = 1/2, this does not imply the statement "The coin will land heads 50 out of 100 times".
As another example, there is deductive principle in logic known as modus ponens that says:
Given:
If A then B
A is true
Conclude:
B is true
There is no principle in logic that allows the argument:
Given:
If A then B
A has probability 1 of being true
Conclude:
B is true
In applying probability to specific problems, people may assume the latter argument to be valid, but the latter argument is not a general principle of logic. It may be valid in specific situations and specific interpretations of probability models.
Assigning probabilities to whether events happen allows us to make deductions about the probabilities of other events happening.
“Yes, your example corrects this statement.”
So, just to be clear; using the classical interpretation in a deterministic world where it’s been determined that the ball will land in a red pocket the P of red is;
P(r) = 1.
P(r complement) = 1-1=0 ?
P(r) = 1.
Yes, that is usual interpretation for the probability of an event that definitely must happen.
Yes.
“Assigning an event a probability does not permit us to make statements about the event happening or not happening unless those statements also speak of probabilities.”
Even if the P is 1? Or if the P is O? I was under the impression that if the P is 1 it must happen, and if the P is 0 it can’t happen; because if the P is said to be 1 and it doesn’t happen then the assertion that the P was 1 was incorrect; and if the P is said to be zero and it does happen then the assertion that the P was zero was incorrect.
“If we say Pr( "The probability the coin lands heads") = 1/2, this does not imply the statement "The coin will land heads 50 out of 100 times".
I get that. In the short run we could see 60 heads, 40 tails, or 80 heads, 20 tails, or even 100 heads, 0 tails. But the more we toss the coin the closer we will get to the expected value. Which is demonstrated by the profitability of roulette for casinos. I even hear mathematicians say that if you tossed the coin an infinite number of times you would get exactly 50% heads, 50% tails. Or if you spun the roulette wheel an infinite number of times you would get exactly 18/37 red, 19/37 non-red. Although that seems to me to be impossible to know so I don’t know how they would justify that assertion.
If the probability is 1, it means you should definitely bet on it happening, but it doesn't mean that it must happen. Similarly, probability 0 means that it almost surely will not happen, but not that it is impossible to happen.
Think about flipping a coin repeatedly. It's not impossible to get all "heads", but it's vanishingly unlikely.
But it's probability wasn't zero prior to it happening, that would be impossible. If, in a deterministic world, it is determined that red will appear, the P of non-red appearing is (using the classical interpretation) zero. In this case non-red can't happen (if it does then it wasn't determined that red would appear).
"Then r has "happened" but its probability is 0. That exact number, r, will never happen again"
Shouldn't that be; Then r has happened and now that it's happened and will never happen again it's probability is 0?
“No, a standard normal random variable has a normal (bell shaped curve) distribution with mean 0 and standard deviation”
Thanks, Dale, but that’s a bit advanced for me at the moment.
“So p=0 doesn't necessarily mean that it cannot happen.”
Is this an instance of the P of something being zero prior to it happening, and then it happening? If so, wouldn’t it's happening contradict the earlier assertion that it’s P was zero?
Thanks, Steven. But I'm talking about a deterministic world where it's been determined that red will win. If, in a deterministic world, it was determined that the next toss of a coin would come up heads then the P for heads is 1, the P for heads is 0, yes? And heads must happen; tails can't happen (anything else would contradict the fact that it was determined to be that way).
“I even hear mathematicians say that if you tossed the coin an infinite number of times you would get exactly 50% heads, 50% tails.
Let's hope not. It's well known that equalizing (i.e. having exactly ##\text{count} = \text{number of heads} - \text{number of tails}= 0##) will happen with probability 1, and hence infinitely many times over these trials. However the expected amount of time until equalization (renewal) is ##\infty## which immediately tells you that the probability of being equalized at any time tends to zero. Infinity is a delicate business.
So suppose a different interpretation of the statement is needed -- they may have been referring to averaging many different trial's counts -- and that average tends to the a count of zero. Or they may have been averaging (read cesaro mean) the score of the trials you are quoting, then applying strong law of large numbers (I suspect that this is what is being done, though the statement has a different interpretations as a symmetric random walk.)
As for your other questions -- impossible events have probability zero. But not all probability zero events are impossible. There are a lot of subtleties related to infinity that keep coming up in these questions, over and over. Bottom line -- wielding infinity properly takes a lot of work and care.
Btw, even if you discover world is 'truly deterministic' I don't think that is going to change how your car insurance, life insurance, etc. is priced.
Sorry, I missed the context. It seems to me that there is no point in talking about probability if everything has probability 0 or 1. But yes, if things are deterministic, then an event is either definitely going to happen, with probability 1, or is definitely not going to happen, so it has probability 0.
On the other hand, even in a deterministic universe, we could probability to quantify our lack of information about the current state of the world, in which case we would introduce probabilities that are neither 0 nor 1, and we would also introduce the possibility of something being given a subjective probability of 0 even though it wasn't actually impossible.
You are correct that a common way to apply probability to real life situations is to assign a probability of 1 to events that must happen and a probability of zero to events that cannot happen.
(As I keep saying, the mathematics of probability theory does not deal with the topic of events "actually happening" or "actually not happening". That subject is a matter of interpreting the matematical theory when applying it to specific situations. By analogy, the mathematical theory of trigonometry does not make specific claims about ladders, distances between cities, heights of trees etc. Those topics involve interpreting the mathematical theory when applying it to specific situations.)
The difficulties in interpreting probabilities of 0 or 1 arise in the applying probability theory to outcomes from an infinite set of values. Your roulette examples have only a finite number of outcomes, so interpreting probabilites of 0 or 1 in those examples is not controversial.
The classical interpretation of P is not defined in such a case. I feel like this is getting annoyingly repetitive.
The classical interpretation of probability is the ratio of successes (red) over the course of an infinite number of trials. It simply is not defined for a sample space consisting of a single unique event. There is no classical interpretation of probability which can apply to this case.
If you wish to extend this to a scenario where the classical interpretation of probability does apply then you will need to extend it beyond a single determined roulette spin to an infinite set of determined spins. Then the question is which infinite set of spins are you considering? Are you considering an infinite set where every spin is determined to be red, or are you considering an infinite set where every spin is determined but what it is determined to be varies. The classical probability does not depend on the determinism, only the long run frequency in the infinite set under consideration.
I gave an explicit counterexample where the thing that happened had a probability of 0 and the thing that had a probability of 1 did not happen.
Yes, it was. That is the whole point.
Then maybe you should focus on the basic mechanics of using probability before you get too deep into the philosophy. I can’t help but feel that you are tying yourself in mental knots here.
https://en.m.wikipedia.org/wiki/Normal_distribution
Yes.
No. In the frequentist case probability is defined as the ratio over an infinite number of trials, and that ratio would still converge to 0. In the Bayesian case it represents our prior subjective belief. Either way the actual result does not contradict the assigned probability.
Looking at many comments on this thread it's interesting how deeply ingrained the idea of determinism is in (non QM) physics.
I don't agree with this at all. It seems to ignore the theoretical unknowability of all the information associated with a complex dynamic system, such as weather or human behaviour.
Those who think physics can predict a coin toss seem to assume that they are able to wait until the coin has been tossed. But, you only have to postulate a future coin toss with unknowns - where and precisely when the toss is to take place, the choice of coin, and the choice of who tosses the coin - to rule out the physics solution.
And, if you believe you could use physics to predict all future human behaviour, then how do you gather the information without changing the people involved?
It's the same with weather systems. Whatever equipment you put into the atmosphere to measure things become part of the system and need themselves to be measured. Plus, the weather is fundamentally affected by the Sun. So, you'll need probes throughout the Sun to predict the weather on Earth.
And, of course, you cannot have probes everywhere. as then the Sun and the Earth word be literally nothing but those probes.
The absolute determinism postulated in this thread is a theoretical impossibility. Probability remains at the heart of physical phenomena, even without the atomic and subatomic uncertainties modeled by QM.
I think that the question is still reasonable (even though the answer seems to be ignored). Determinism is certainly part of classical mechanics, and probability is certainly used to model classical systems.
@PeroK , I would call your examples "practically unknowable" rather than "theoretically unknowable". Whereas there are too many factors to determine practically, anyone of them can be determined, in theory. I think that the only "theoretically unknowable" aspects are those that are intrinsically random, like quantum phenominum.
That being said, I like to think that probability is the theory of guessing, given incomplete information. That avoids the issue of why the information is incomplete. It also allows the application of probabilities to things that have already happened and can be determined, but are still unknown (like a coin already tossed whose result is hidden.)
Well, that's the two different interpretations of probability at play. A system can be modeled as a stochastic process, where the next state is only probabilistically connected to the current state. Or a system can be modeled as a deterministic process, but may depend on parameters that are not perfectly known. Both ways of modeling the system can give rise to probabilistic predictions. But when people say that a system is deterministic, I think they mean that it is not stochastic. It might still be unpredictable (because of lack of perfect knowledge of the current state), so probabilities may still be appropriate.
Yes, there are difficulties with the idea that a physical system can be deterministic, but compare those to the difficulties with the idea that a system is "probabilistic". It is unclear how to define probability as physical phenomenon that has an objective existence. And if we resort to the concept that probability is a measure" of information or ignorance then how do we define information or ignorance? The way that approach ends up is circuilar - probability is a measure of information or ignorance and information or ignorance is something measured by probability.
Perhaps we should discuss this in the thread https://www.physicsforums.com/threads/how-to-better-define-information-in-physics-comments.949993/
Regardless of the theoretical difficulties involved, we should not give up the ability to treat a future coin toss as a 50/50 probability. We should also not give up the ability to treat a coin toss which has already happened but whose outcome is unknown as a 50/50 probability, even though the outcome is already completely determined. Any satisfactory theory must allow those at least.
This is a great point. It shows that determinism does not need to impact probability.
In the frequentist approach this would be considered to be the frequency of an infinite number of coins already tossed but not examined. In the Bayesian approach it would simply be our subjective assessment prior to learning the data.
“Let's hope not[that some mathematicians say that if you tossed the coin an infinite number of times you would get exactly 50% heads, 50% tails.].”
Thanks, I will challenge the next one that tells me that.
“It's well known that equalizing (i.e. having exactly count = number of heads − number of tails =0) will happen with probability 1, and hence infinitely many times over these trials. However the expected amount of time until equalization (renewal) is ∞∞ which immediately tells you that the probability of being equalized at any time tends to zero. Infinity is a delicate business.”
I Googled equalizing but I wasn’t sure from the results which one applied to what you said. What do you mean here by equalzing?
“So suppose a different interpretation of the statement is needed -- they may have been referring to averaging many different trial's counts -- and that average tends to the a count of zero.”
Looking at actual data, from real life spins of the wheel, or tosses of the coin? Then averaging them? Does ‘tend to the count of zero mean get closer and closer to zero as more and more trials are performed?
“As for your other questions -- impossible events have probability zero.”
So on a European roulette wheel the P of the ball landing in a blue pocket marked 37 is 0?
And in a world where it is determined that the ball will land in a red pocket the P of it landing in a non-red pocket is 1?
“But not all probability zero events are impossible.”
Yes, Dale (kindly, and patiently, explained this, but his example was too advanced for me – I’m, as you will probably have gathered) a novice). Can you give a simple example of an even with a P of zero that is possible?
“There are a lot of subtleties related to infinity that keep coming up in these questions, over and over. Bottom line -- wielding infinity properly takes a lot of work and care.”
Yes, I’m coming to realize that. The notion of “approaching infinity” regards spins of a roulette wheel, for example, seems to me problematic. If we run larger and larger numbers of trials, say a trillion, then a quadrillion, all the way up to the largest numbers that we have names for, then run further trials that require us coming up with new names for the numbers (numbers that dwarf the numbers that we already have names for) we are no more closer to infinity than had we ran a mere 37 trials. Once we get to a ‘gazillion’ trials, infinity is still infinitely far away. What is infinity minus 1? What is infinity minus a quadrillion?
Also, I’ve read that Cantor showed that there are various infinites, and demonstrated it using pure maths, but it seems to be problematic to say that one infinity can be larger than another. Take the cherries in a bowl example. If you have 10 bowls of cherries with 10 cherries in each do you have more cherries than bowls. Well, it appears that you have 10 times as many cherries as bowls yet you have an infinite number of bowls so...(?)
“Btw, even if you discover world is 'truly deterministic' I don't think that is going to change how your car insurance, life insurance, etc. is priced.”
:o)
I also think it is intellectually satisfying to think of it as the "theory of guessing, given incomplete information" when Bayes' Rule is used to calculate a mixed situation of the unknown outcome where some information is given (Bayesian updating).
Yes, although I think the Bayesians prefer “reasoning under uncertainty” over “guessing, given incomplete information”. At least that is the terminology I have seen used.
Suppose you start flipping a coin. It's possible that you will always get "heads", although the probability of that is 0%.
