How much force does a moving car exert on to the road?
  • Thread starter Thread starter MustafaTekinay
    Car Force Weight
The discussion centers on the force exerted by a moving car on the road, emphasizing that the car's weight remains constant regardless of speed, as defined by the equation f=mg. Aerodynamics plays a role in force dynamics, with typical road cars generating lift and racing cars producing downforce. Weight transfer occurs during acceleration and braking, affecting weight distribution but not the total force. The consensus is that slower-moving cars do not necessarily cause more peak strain on the road surface compared to faster vehicles.
  • Understanding of Newton's laws of motion, particularly f=mg
  • Basic knowledge of aerodynamics and its effects on vehicle dynamics
  • Familiarity with weight transfer concepts in vehicles during acceleration and braking
  • Knowledge of road surface behavior under dynamic loads
  • Research the impact of aerodynamic lift and downforce on vehicle performance
  • Study the mechanics of weight transfer in vehicles during different driving conditions
  • Explore the relationship between vehicle speed and road surface strain
  • Investigate the effects of tire pressure and design on road contact stress
Automotive engineers, physics students, and professionals in vehicle dynamics and road engineering will benefit from this discussion.
MustafaTekinay
Does a faster car exert less force on the ground at a given point and a given time compared to a slower one? Do the slower moving cars cause more peak strain value at a given point on the road?
F=ma
I understand that the weight of the car does not change (assuming mass of the car stays the same) because of f=mg. But I am not so sure about of the aerodynamics of the car plays a role. Say, a faster car might have more air under their wheels and might exert less force on to the ground. Maybe a faster car exerts less force on to the ground because of the time it takes the weight of the car to transfer to the ground.
Thanks for the help.
The car can be viewed as a wing and can generate an aerodynamic lift force or a downforce that is added to (or subtracted from) the total weight of the car. Typical road cars generate a lift force, but racing cars most likely generate a downforce by design.
Also, during acceleration or braking (independent of speed), there will be a weight transfer between the front and rear axles. This doesn't modify the total force due to the weight of the car, but it modifies the weight distribution between the two axles. The same thing happens with the lateral acceleration and the right & left wheels weight distribution.
MustafaTekinay said:
Homework Statement:: Does a faster car exert less force on the ground at a given point and a given time compared to a slower one? Do the slower moving cars cause more peak strain value at a given point on the road?
Have you copied the homework statement exactly?
A literal and careful reading of the phrase "peak strain value" would mean peak deflection of the road surface under the force of the car's tires. So one would want to think about the behavior of the road surface over time.
I would not try to bring aerodynamics into the question. Adding complications will not simplify things.
... Maybe a faster car exerts less force on to the ground because of the time it takes the weight of the car to transfer to the ground.
That is an incorrect assumption.
Is the problem referring to straight trajectory, cornering or both?
Thanks for the reply. So for typical cars, the strain will be less?
Thanks for the reply. Not word by word but the question is the same.
Thanks for the reply. Would not aerodynamics play a role in the amount of force the wheels exert on the ground. If the car is flying over the road, then there would not be (almost) no force exerted on the ground.
Thanks for the reply. Imagine a road and a vehicle at a constant speed traveling in a straight trajectory. Would the tires cause more stress or strain on the ground if moving slower?
The aerodynamics can act either way. High performance cars have inverted aerofoils to press them down onto the road for better roadholding. Even a regular passenger car would not be designed so as to lose traction at high speed.
You are welcome, Sir.
The tires would not cause more stress or strain on the ground if moving slower.
:cool:
:cool:
Why not more stress? Why not more strain?
I may be wrong, but I assume that neither static or dynamic loads on the interphase (contact patches-asphalt) could be greater for the same vehicle, road's surface and dynamic conditions.
"Strain" is not about load. It is about deflection.
  • · Replies 36 ·
