How much gunpowder does a rocket need?
  • Thread starter Thread starter 168918791999
    Rocket
69 replies · 8K views
168918791999
m=100gr
g=9.81 m/s2
H=75m
Combustion of gunpowder = 2.7x10^6 J/Kg
This would mean we only need 0.2gr of gunpowder to get 75m high.
Why is there in a normal rocket more gundpowder?
Our physics and chemistry teacher checked my calculations but couldn't find a mistake, so what is the problem?
U=m*g*h
U=Joules
M=Kg
g=gravitational acceleration
H=height in meters
Average rocket is 10% efficient
U=0.1*9.81*75
U=73.57500J
U*10=735.8J
1000gr | 2.7*10^6
X | 735.8
X=Gunpowder needed
X=1000*735.8/2.7x10^6
X=0.27251851851gr
168918791999 said:
m=100gr
g=9.81 m/s2
H=75m
U=m*g*h
U=Joules
M=Kg
H=height in meters
U=0.1*9.81*75
U=73.57500J
U*10=735.8J
1000gr | 2.7*10^6
X | 735.8
X=Gunpowder needed
X=0.27251851851gr
You don't just pick up a rocket and put it on a shelf 75 m above the ground.
What about the KE of the rocket as it shoots upward, accelerating against the gravitational pull of the earth?
The work the rocket engine does on the rocket (and thus its efficiency) is highly dependent on the flight characteristics. One extreme: a burning rocket engine that fails to lift off does zero work on the rocket and has zero efficiency.
A rocket works on the principle of conservation of momentum. The rocket engine has nothing solid to push against.
Most of the energy goes into the exhaust fuel. How much goes into lifting the rocket depends on how quickly the fuel burns. You could have a vast supply of fuel, yet it burn it so slowly the rocket never lifts off.
You could take the optimum, that all the fuel burns instantly, and use momentum to figure out the speeds of the exhaust gas and the rocket lift-off.
I'm sorry but how can i calculate the momentum of the rocket if the fuel of the rocket is gundpowder?
Kinetic energy?
Also I don't think that is how a gun powder driven rocket operates.
The gp is used to bring it up to a max speed in a very short time period, or distance, and then it operates like a "thrown" projectile the rest of the distance.
You have the mass of the rocket and the mass of the gunpowder. The combusted gunpowder will have a greater mass.
Suppose the rocket takes off at speed u and the gunpowder exhaust gases exit at speed v. What equations can you write down?
Also a lot of the energy made availble by the gp will be used to do work against drag.
A typical drag coefficient seems to be 0.75.
andrevdh said:
Kinetic energy?
Well, it takes energy to get the rocket moving at a non-zero velocity. The gunpowder is not like a compressed spring which throws the rocket upward when it is tripped.
Also, this rocket is only going 75 m. Drag is not a significant factor if the velocity is low.
SteamKing
For 75 J of kinetic energy the max speed needs to be about 40 m/s which is about 150 km/h,
but you are saying it burns throughout the whole stage? Shouldn't it stop burning way before
75 m in order to reach zero velocity at the top?
So to calculate the kinetic energy I found the equation:
KE=½*m*v2
mass = 100gr
velocity = 40 m/s (I still don't know how you found this number)
KE=80000J
and the gunpowder you would need is
80000*1000/2700000 ≈ 29.63 gr
thank you for your response this number is more likely but I am still not sure if I did it right
KE=½*m*v2
mass = 100gr
KE=80000J
Units matter. The formula for KE=½mv2 only works if your measurements are all in the same system of units (and assumes that it is not a gravitational system). To be consistent with Joules and meters per second, the mass of your object needs to be expressed in kilograms.
This is still incorrect. It assumes that all of the energy in the gunpowder is delivered to the payload and that none is delivered to the exhaust stream. The exhaust stream will be moving fast and will be carrying away a LOT of kinetic energy. That means that the result you have obtained (once corrected for the kilogram versus gram problem) is dramatically understated.
That is what Haruspex was getting at in #4 above. If you want to figure out how much energy goes into the exhaust stream, it helps to know the velocity of the exhaust stream. Haruspex in #7 above was suggesting that you start things off by treating it as an unknown named v. Post #10 above suggested that you could calculate the exhaust velocity from the information you already have.
Try looking at #7 again and see what problems you run into.
If you find the amount of gunpowder needed is not intuitive you might consider an experiment done
by a group of high school students measuring the muzzle velocity, of a .223 caliber rifle, versus
the powder load.
To be brief they obtained velocities in the neighborhood of 2500 ft / sec using around 25 grains of
powder or something less than 2 grams.
Using the range formula R = V^2 / g you would get a range (maximum) of 37 mi.
In practice the maximum range would be much less than this because of air resistance.
the powder load.
A rifle might not be sufficiently like a rocket. A rifle traps the exhaust gases in a chamber, allowing more of the energy to be transferred to the bullet.
the powder load.
I wonder about that range formula. Sure, you get units of length out, but is this formula like an old Wives' Tale?
Range is dependent on initial firing angle, and there's nothing about firing angle in this formula.
Even firing a rifle perfectly horizontally, the bullet remains in the air for an amount of time equal to what it takes for a stationary bullet to free-fall to the ground. For a rifle held horizontally 1.5 m above the ground, that's a little over half a second. The range of the bullet therefore would be a little over 1250 feet or so, if it leaves the muzzle at 2500 fps, not 37 miles or some ridiculous distance.
As Haruspex points out, we are not talking about a bullet fired from a rifle. Nor is the velocity of a bullet as it leaves a rifle particularly relevant to computing the exhaust velocity for gunpowder expelled from a rocket.
Perhaps we should be focusing more carefully on the original problem.
The range formula is actually R = v^2 * sin (2 theta) / g.
The maximum range occurs at theta = 45 deg.
My example only referred to the maximum range.
Even firing a rifle perfectly horizontally, the bullet remains in the air for an amount of time equal to what it takes for a stationary bullet to free-fall to the ground. For a rifle held horizontally 1.5 m above the ground, that's a little over half a second. The range of the bullet therefore would be a little over 1250 feet or so, if it leaves the muzzle at 2500 fps, not 37 miles or some ridiculous distance.[/QUOTE]
[/QUOTE]
Guys, please stop discussing rifles and bullets on this thread. They are really not relevant to the question at hand. By all means start another thread for it.
P=m*v
So the momentum of our rocket would be 0.1*40 so 4 Newtons per second
So what now?
What is your Physics background?
P=m*v
So what now?
That 40 meters per second comes out of the blue at post #11. It is not trustworthy. The point of these forums is not to give you the answers. It is to give you the ability to find the answers. So before we proceed forward, we need to see how to get this far. There are two steps.
First, we need to figure out the best "burn pattern" for our gunpowder rocket. This sort of optimization problem is pretty advanced subject matter. Stuff that you can handle with the "calculus of variations". But we can get by with some more simple-minded heuristics.
Suppose that we light off the motor and that it burns at a steady rate. The rocket rises at a constant acceleration and eventually passes 75 meters. Are there any problems with this acceleration profile? Can we do better?
Problem 1: The rocket passes the 75 meter mark with residual velocity. We could turn the motor off and coast partway through the trip and do better.
Problem 2: We are carrying fuel up partway into the trip and burning later. We've wasted energy lifting that fuel. We'd be better served burning it lower.
Problem 3: We are taking time in the flight. The more time we take, the longer gravity has to act. All other things being equal, we'd be better off if we could make the trip take less time -- by increasing our average velocity.
The bottom line is that we are better off burning our fuel off quickly at the bottom and then coasting to the top, crossing the 75 meter mark with no velocity remaining.
Haruspex mentioned this in #4. Andrevdh addressed it in #6.
Second, we need to figure out what velocity we need to have at the end of that short burn in order to coast 75 meters up.
Can you find the velocity that the rocket needs to rise 75 meters into the air so that it arrives at the top with no remaining speed? Alternately, can you find the speed it will have if it falls from 75 meters up and crashes into the ground? [the two answers should be identical].
P=m*v
So what now?
No, you don't have that yet since the velocity is what we're trying to find. (And it's Newton seconds, Ns, not Newtons per second, N/s.)
You know the mass of the rocket, but not the velocity.
You know the mass of the gunpowder, but not the velocity of the exhaust gases.
You know that momentum is conserved, ##\Sigma m_iv_i=0##
You know the energy released. If you assume all that gets converted to KE you have ##\Sigma \frac 12m_i{v_i}^2=E##.
Two equations, two unknowns. Solve.
Edit: Funny, I didn't see the other replies until I posted that.
Jbriggs gives a much more complete answer. Mine is just for the extreme (optimal) case that all the fuel is burnt instantly. Without that assumption, you need to know the burn time and pattern, and get tangled up with a varying mass payload.
PE=m*g*h
KE=½*m*v2
m=100g
g=9.81 m/s2
h=75
PE=KE
m*g*h=½*m*v2
9.81*75=½*v2
735.75*2=v2
v=√1471.5
v=38.36 m/s
Is this correct?
So now the momentum would be:
P=m*v
m=0.1kg
v=38.36 m/s
P=0.1*38.36
P=3.836 Ns
It must be the same because of conservation of momentum?
it must be half of the momentum because toghether it must be 3.8Ns
so 1.9 Ns
so 1.9 Ns
No, they have the same magnitude of momentum, but opposite signs. The total must be zero.
So you have three unknowns:
The mass of the gunpowder (which I presume is the same as the mass of the exhaust gases)
The energy in the gunpowder
The exhaust speed of the gases
These are related by three equations:
Energy density of the powder
Total momentum=0
Energy of the gunpowder = total KE (at least)
