Infinityze
- 18
Suppose you had a rotating magnet, about the size of a penny, about how much friction/heat could it make in watts?
The forum discussion centers on the feasibility of generating heat and electricity using small magnets, specifically a rotating magnet the size of a penny. Participants clarify that friction and heat generation require contact with another surface, making the magnetic property irrelevant in this context. They suggest that a more efficient method would be to use a magnet in a coil setup, akin to a traditional generator, rather than relying on friction. The conversation also highlights the limitations of magnetic fields over distance and proposes alternatives like motor-generators for converting energy.
PREREQUISITESEngineers, hobbyists, and inventors interested in small-scale energy generation, particularly those exploring innovative uses of magnets and thermoelectric systems.
hi thereInfinityze said:Suppose you had a rotating magnet, about the size of a penny, about how much friction/heat could it make in watts?
davenn said:hi there
welcome to PF
friction and heat generated from it requires it to be "rubbing " against something
it wouldn't be any different to a plain metal disc .. being magnetic is irrelevant
Explain more clearly what you are trying to discover
Dave
Infinityze said:why its a magnet is not important for this discussion, but it just is :P).
Infinityze said:is there like a formula or relationship between friction and heat produced?
Infinityze said:I'm looking for a way to produce heat (and then electricity with a thermoelectric converter) using friction created by a magnet
davenn said:why don't you just spin the magnet in a coil like a normal generator ? ... would be much more efficient ... ie ... wouldn't have the huge energy losses
Infinityze said:Sorry for being vague earlier, but I guess this is where the size comes in. I want it to be as small as possible, like the whole thing would be a few centimeters or inches tops.
davenn said:do some googling on electrical generators and alternators
Infinityze said:Okay, I did and it helps a lot. Let me pose my problem this way, is there any way I can make one magnet produce mechanical energy once it is in range of another (perhaps through friction)?
Drakkith said:Magnets don't produce energy, they only help convert it from one form to anther. For example, magnets used in generators convert mechanical energy to electrical energy. There are multiple ways of producing electricity on a very small scale. To help find the best method we need to know the details of what you're trying to accomplish or we aren't going to be able to help you much.
Infinityze said:Okay now that I have a better picture, want to power a generator from a distance (at least 10-20 ft) automatically. I was thinking maybe two magnets could work, if one could make the other generate mechanical energy. Would this work? If not, is there something else that would?
Drakkith said:How much power are you looking to get out of this generator? If it's only a very small amount there may be other options we haven't considered.
Infinityze said:Interesting, would this be able to stay small-scale or would it get too big? I'm looking to get around 5-10 watts out of it.
Drakkith said:How about a solar panel and a focused light source? Simple to set up, no moving parts, works night and day.
