How much water boils off when a hot horseshoe is dropped in
  • Thread starter Thread starter Shmiam
    Hot Water
The problem involves a blacksmith dropping a hot horseshoe into a bucket of water, raising questions about heat transfer and the amount of water that boils off as a result. The subject area includes thermodynamics and heat transfer principles.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the use of the equation Q = mc delta(T) to analyze heat transfer between the horseshoe and water. There are attempts to understand how to calculate the heat absorbed by the water and the heat lost by the horseshoe. Questions arise about the temperature changes and the conditions necessary for water to boil.
The discussion is ongoing, with participants exploring various interpretations of the heat transfer process. Some guidance has been provided regarding the need to consider the temperature of the water reaching 100°C before boiling occurs, and the relationship between the heat gained by the water and the heat lost by the horseshoe is being clarified.
Participants are working under the assumption that no energy is lost from the system, and they are considering the implications of this assumption on the calculations. There is also a focus on the specific heat capacities of the materials involved and the need to define variables clearly.
Shmiam
A blacksmith drops a 0.7 kg horseshoe of iron at a temperature of 1200 ̊C into a bucket of
0.5 L
of water at an initial temperature of 30 ̊C. How much of the water boils off? Assume the bucket
absorbs none of the heat.
I believe Q = mc delta(T) is what I'm aiming to use here, but I'm not entirely sure how
I'm a bit lost, I know that the two objects (shoe and water) will ultimately reach the same final temperature, and I can write Q = mc delta(T) to reflect that, but I'm unsure how it corresponds to the water that boils off, and how I might find that value? I'm guessing it'd be the volume of steam which will share the same final T as the water and shoe? Not sure how to find it though.
Thank You
No, the steam will come of at 100C and take no further part.
Think of it in stages, and assume that at any given moment all the water is at the same temperature.
What must happen before any water boils off?
The water needs to rise to 100C first, right? I'm just generally confused how to work the equation up to that point, and then what I need to do to find how much water boils off.
Yes.
What heat will the water have absorbed? What temperature drop occurs in the horseshoe?
Do they both end up at 100C? So the horseshoe would drop 1100C? But then for the heat absorbed by the water, I am not sure what it equals. Is it related to the horseshoe's Q = mc delta(T)? As in, I solve that with delta(T) = 1100C and that's how much heat the water absorbs?
Eventually, perhaps, but at this stage we are just considering the process up to the point where all the water is at 100C. The horseshoe may still be hotter.
Answer my first question: how much heat has the water taken up at this point?
Would that be = mc(70C)?
Maybe - you have not defined m and c.
c is the specific heat of water and m is the mass, which, using density, would be .5kg
OK, so how much heat has gone from the horseshoe?
Would its temperature change also equal 70C?
I didn't ask that.
You calculated that the water absorbed mc (70C) of heat. So how much did the horseshoe lose in that time?
What I meant by that was whether the horseshoe lost mc (70C) or if that's the wrong way to think about it
You need to base your thinking on sound principles, not wild guesses.
It is a very simple question: if the water gained a quantity Q of heat from the horseshoe, what quantity of heat did the horseshoe lose to the water?
I'd have to say I don't know
Heat is energy. Energy is conserved. If the total stays the same, but the water gained Q, how much did the horseshoe lose?
Oh, then the horseshoe must have lost Q
Right. So what is the temperature of the horseshoe at this point?
So, setting the two Q's equal, I found delta(T) of the shoe to be = -(mc 70C)/(MC)
m - mass of the water
c - specific heat of water
M - mass of the shoe
C - specific heat of iron
Ok. Time to turn that into a numerical temperature.
I think I must be missing something here
m = .5kg
c = 4187 J/(kg*K)
M = .7kg
C = 460.548 J/(kg*K)
and 70C + 273K = 343K
I'm getting an outrageously high change..
m = .5kg
c = 4187 J/(kg*K)
M = .7kg
You don't need to convert to K. A change of x degrees in C is also a change of x degrees in K, and here we are only concerned with temperature changes.
The heat gained by the water is mc(100-30) or, equivalently, mc((273+100)-(273+30)).
0.5 L
According to the problem you know that no energy is lost from the system, therefore you can say that the change in energy of zero is equal to the sum of every Q. The Q you'll have to account for include the heat loss from the horseshoe, the heat gained to bring the water up to 100C, and the heat gained to evaporate the water. Heat exchange will continue until either the horseshoe is removed, or they come to thermal equilibrium. If you assume that not all of the water will evaporate, this tells you the final temperature of the horseshoe, which should then allow you to solve for its Q (if this turned out to be an incorrect assumption, you would be able to tell because you would find that all of the water evaporated, but then that would also be your answer).
In that case, the horseshoe loses 454.567K
Right. And now we have all the water at 100C.
What process will happen next, and what will eventually halt that process?
The water goes through its phase change from liquid to steam, and it stops if it all evaporates or if the system reaches thermal equilibrium
Good.
How much heat does the horseshoe still have to lose for equilibrium?
haruspex said:
Good.
At equilibrium it would match the temperature of the water, so Q = MC(373K-1018.433K), which comes out to be -208076.96J?
Right, so how much water will boil off.
If there were no water boiling off, how would you use ##Q=mc\Delta T## to find the final temperature?
  • · Replies 17 ·
