How much work to push a spring up/down a distance of y?
The discussion focuses on calculating the work required to displace the midpoint of a spring by a distance of y. The relevant formula for work done on a spring is W = -1/2k(b²-a²), where 'a' is the original length of the spring (L) and 'b' is the new length after displacement. The correct approach involves using Pythagorean theorem to determine the new length of the spring as 2√(y² + (L/2)²). The final expression for work done is W = k(-1/2y² + 3/8L²), accounting for the spring's extension on both ends.
  • Understanding of Hooke's Law and spring constants (k)
  • Familiarity with the concept of work in physics
  • Knowledge of Pythagorean theorem
  • Basic algebra for manipulating equations
  • Study the derivation of Hooke's Law and its applications in mechanics
  • Learn about energy conservation principles in spring systems
  • Explore advanced applications of Pythagorean theorem in physics problems
  • Practice solving work-energy problems involving springs and forces
Students studying physics, particularly those focusing on mechanics and spring dynamics, as well as educators looking for examples of work calculations involving springs.
Jim01
The ends of a relaxed spring of length L and force constant k are attached to two points on two walls separated by a distance L. How much work must you do to push the midpoint of the spring up or down a distance of y?
W = -1/2k(b2-a2) (after integration), moving from y=a to y=b
I'm completely lost on this. The first thing that I notice is that when you push down on the midpoint of the spring, you form two right triangles. This leads me to believe that y will go from a value of zero to the value of Fy, where F is the downward force on the spring. So I made a force diagram and came up with summation of forces.
\sumFx = 0
wx = 0
Fx = L/2
Fx= 0
\sumFy = 0
wy = -mg
N = mg
Fy = -Fcos\theta
wy-N-Fy = 0
Fy = wy-N = -2mg
I attempted to use the Fy value as b in the W = -1/2k(b2-a2) formula but this led me to a wrong answer. I then tried to put Fx into the equation, thinking that maybe I needed to get Fy from the net forces. This led me nowhere either (I was grasping at straws here).
I am obviously going about this the wrong way. Since it involves the work on a spring, I know that I must use the W = -1/2k(b2-a2) formula. I just have no idea how to get the value of b. What concept(s) am I missing here?
There is no need to resolve forces. The crux of the question lies within this: by what length has the spring been stretched? It then results in a clear application of that formula you are brandishing around.
Hint: It involves the right angle triangles you've been talking about and Pythagora's theorem of course
I know I'm thickheaded because I'm still not seeing it. If I set the opposite to y, the adjacent to L/2, this gives me a hypotenus of the square root of y2+(L/2)2.
So at rest, the spring length is L. So a=L and b= the square root of y2+(L/2)2. However when I plug this into my formula, it still doesn't work. I end up with
W = -1/2 k [(square root of y2+(L/2)2 - L2]
= - 1/2k [y2+(L/2)2 - L2]
= - 1/2k [y2 - 3/4 L2]
= k(-1/2y2 + 3/8 L2)
This is because you forgot to consider the fact that the spring is stretched on both ends. So the length of the extended spring is 2\sqrt{y^2 + (\frac{L}{2})^2}.
  • · Replies 58 ·
