How Should Charge q Be Allocated for Maximum Force on Two Objects?
  • Thread starter Thread starter Air
    Charges Force
9 replies · 7K views
Air
A small object has charge [itex]Q[/itex]. Charge [itex]q[/itex] is removed from it and placed on a second small object. The two objects are placed [itex]1[/itex] meter apart. For the force that each object exerts on each other to be a maximum, q should be:
[itex]F=\frac{kQ_1Q_2}{r^2}[/itex]
The correct answer is [itex]\frac{Q}{2}[/itex] although I can't seem to get to that. Is my formula selection correct. Also, if force is maximum, which value do I cosider it as. Thanks for the guidence in advance.
Good; here [itex]r=1\text{m}[/itex], so you might as well write this as [itex]F=kQ_1Q_2[/itex] and not worry too much about the units.
Now, what are [itex]Q_1[/itex] and [itex]Q_2[/itex] for this problem (in terms of 'Q' and 'q')?
Well, you should have an equation for your force that is a function of 'q'; if I gave you some function of x and asked you to find the value of x that gives maximum value of that function, how would you do it? Apply the same idea to the force as a function of q.
It it was function of [itex]x[/itex], I would differentiate to find the maximum and equate it zero. How is that relevant?
EDIT: [itex]F = KQ^2\implies \frac{\mathrm{d}F}{\mathrm{d}Q} = 2KQ[/itex]. Is this correct?
Well, if you have a function of x you differentiate with respect to x and set it equal to zero.
So, if you have a function of q, why not differentiate it with respect to q and set it equal to zero? :wink:
Ok, So if [itex]F=kQ_1Q_2[/itex], we can consider the charge to be [itex]F=kQ^2[/itex] hence as [itex]F = KQ^2\implies \frac{\mathrm{d}F}{\mathrm{d}Q} = 2KQ[/itex].
[itex]2KQ = 0 \implies Q=0[/itex]. Hmmm... Is my error that I changed [itex]Q_1Q_2[/itex] to [itex]Q^2[/itex]? :redface:
Right idea, but are [itex]Q_1[/itex] and [itex]Q_2[/itex] really both equal to [itex]Q[/itex]?
If the first object starts out with charge [itex]Q[/itex] and you take away an amount [itex]q[/itex] how much is left? Call that [itex]Q_1[/itex].
If the second object starts out neutral and you add an amount of charge [itex]q[/itex], what is the charge on that object? Call that [itex]Q_2[/itex].
[itex]F=k(Q-q)(q)[/itex]
[itex]F=KQq - Kq^2[/itex]
[itex]\frac{\mathrm{d}F}{\mathrm{d}q} = KQ - 2kq[/itex]
When derivative equated to zero, max can be found: [itex]0 = KQ - 2kq \implies KQ = 2Kq \therefore q = \frac{Q}{2}[/itex].
Woo, it works. I got the correct answer. Thanks a lot for the great help. You've been very patient and I appreciate the help. Thanks once again. :smile:
That's much better!:smile:
You should also check that the second derivative is negative so that you can be sure that you've found the maximum value and not the minimum value.
Yes, [itex]\frac{\mathrm{d}^2F}{\mathrm{d}q^2} = -2q[/itex] Which is negative hence it's a maximum.
