How the power of the voltage supply can be calculated?
The discussion revolves around calculating the power of a voltage supply in the context of a physics problem involving electric and magnetic fields, specifically related to a particle's motion in a velocity selector region of a spectrometer. Participants explore the implications of having parallel plates and the role of current in this scenario.
  • Participants question whether the problem statement is complete and clarify the relationship between the electric field, particle acceleration, and current. There is discussion about the nature of power in relation to the voltage supply and whether the situation can be modeled as a capacitor.
The discussion is ongoing, with participants providing insights and raising questions about the definitions and assumptions involved. Some guidance has been offered regarding the nature of the electric field and its relation to the voltage source, but no consensus has been reached on the specific calculations or interpretations required.
Participants note that the original problem statement may lack crucial details, and there is an emphasis on understanding the definitions of power and voltage in this context. The problem is situated within a spectrometer's velocity selector region, which adds complexity to the discussion.
requied
What should be the power of the voltage supply below that we use for producing electric field .
P=IV = IR^2 =V^2/R
I know only these relevant equations for power. But here there is a different situation, we have a parallel plates which we don't have to know I current. How should I think of about this? I wonder if it can be thought of a capasitor or something?
Assume that also we know E, B and velocity .
Did you give the complete statement of the problem? In your drawing you show a magnetic field and a particle moving through the E and B fields. But, the problem statement doesn't mention anything about these.
Are you supposed to find the power of the voltage supply or are you supposed to find the voltage of the power supply?
From what you have shown, it looks to be a simple capacitor, so no current is flowing. If I=0, then what is the power?
I am guessing that the OP is troubled by the following fact:
As the particle accelerates under the influence of electric field, if this accelerated movement corresponds to some sort of current, and where the energy comes from that increases the kinetic energy of the particle.
My answer to this is that though this movement is indeed a current, still this current is not drawn from the voltage source, and the energy that increases the kinetic energy of the particle does not come from the source but from the initial potential energy of the particle inside the field.
The energy to produce the E-field is drawn from the voltage source and it is $$E=\frac{1}{2}CV^2$$ where C the capacitance of the capacitor. This energy is drawn when capacitor is charged.
requied said:
Relevant Equations:: P=IV = IR^2 =V^2/R
You might want to verify those for future use, one of them is incorrect.
I spesified it on the homework statement.
It's that easy really? I supposed that I would do some complex calculations :/
I didn't ask the question for anything about the kinetic energy of the particle. You misunderstood me . I just wondered that what is the voltage supply's power.
No power is required to maintain the electric field in isolation. The moving particle, which you did not mention in the problem description, must be relevant.
Would I be right in thinking there is a stream of such particles? Whatever, please post the entire question as given to you.
This looks suspiciously like the sort of problem where one should calculate the potential difference between the deflection plates that will result in a linear trajectory for a given charged particle passing through a fixed magnetic field.
The OP needs to provide his definition of "power" for the voltage source, and the specifics of the particle.
This is a piece of a spectrometer question and this region above is the velocity selector region. The question says "What should be the power of the voltage supply that we will use in velocity selector region?".
I think it is not a problem to just take this area about the question. I assumed that we already know the values I found in other regions
That will occur on spectrometer
  • · Replies 0 ·
  • · Replies 51 ·
  • · Replies 52 ·
