How the suggestion to found the time travel award
The forum discussion centers on the theoretical concepts of negative mass and its potential application in time travel, particularly through wormholes. Participants express skepticism regarding the current understanding and feasibility of negative energy production, with references to notable figures like Jack Sarfatti and discussions on tachyons. The conversation highlights the distinction between negative mass and negative energy, emphasizing the challenges of creating a macroscopic wormhole for human travel. Theoretical models, such as the L-S-E wave, are proposed as mechanisms to facilitate faster-than-light travel.
  • Understanding of negative mass and its implications in physics
  • Familiarity with wormhole theory and its role in time travel
  • Knowledge of tachyon particles and their properties
  • Basic concepts of quantum gravity and its speculative theories
  • Research the properties and implications of negative mass in theoretical physics
  • Explore the current theories surrounding wormhole creation and stabilization
  • Investigate tachyon theory and its relevance to faster-than-light travel
  • Study quantum gravity theories and their predictions about the structure of spacetime
Physicists, theoretical researchers, and science enthusiasts interested in advanced concepts of time travel, negative mass, and the underlying principles of quantum mechanics.
hey.like
To get into time travel, the negative mass structure is reasonable as it is ease to exceed the c. This is a very hard question. The negative mass traveler invention and patent would be awarded. Is it right the ten millions money award.
Who can do it ready ? Help please!
Boy that's the 64 femtomillion buck question. Negative energy production would be the prize, but nobody right now has a clue of how to do it. Most of those who are erven trying are pretty far over toward the crank direction. Sarfatti keeps posting but if you follow his posts over the last couple of years, you find he's stuck and won't admit it. He's go a cute idea for his derivation of the dynamical cosmological constant Lambda, but it's just definition, definition, definition (and squabbles with Hameroff, the ZPE man). No conclusions, no methods.
Boy that's the 64 femtomillion buck question. Negative energy production would be the prize, but nobody right now has a clue of how to do it. Most of those who are erven trying are pretty far over toward the crank direction. Sarfatti keeps posting but if you follow his posts over the last couple of years, you find he's stuck and won't admit it. He's go a cute idea for his derivation of the dynamical cosmological constant \Lambda, but it's just definition, definition, definition (and squabbles with Hameroff, the ZPE man). No conclusions, no methods.
Thank you reply carely!
Thank you to reply, I think. the negative mass is different the nagative energy, as the relativity is not right in negative mass . energy is not equal the mass. as some secret event like UFO and so. it is fast perhaps.
Thanks.
As careful a reply as I can do
Thanks.
Mmmm I think relativity is still valid. With negative energy, positive mass you have e^2 < p^2c^2 - m^2c^4, which is the condition for a virtual particle in the quantum vacuum. On the other hand a negative mass particle is a tachyon, which is a perfectly good relativistic particle that always travels faster than light. Just as we can't accelerate up past the speed of light to its domain of speed, so it can't decelerate down past the speed of light to ours. Same reason in both cases; it takes an infinite amount of energy to do that.
Warning. Many string and brane theories predict tachyons, but they also predict that they would be unstable and collapse the quantum vacuum to a lower energy level. Since that would be sort of like the end of the world, we don't want to see it happen.
Is The negative mass in a worm hole?
I read the negative mass is in a wormhole in www.[/url] sciam.com and search by [url]www.google.com.[/URL]
Now it is a hot direction. but it is puzzle.
As the relative theory and in a mini wormhole, Is the negative mass true in a worm hole?
[How could one build a time machine? The simplest way currently being discussed is to take a wormhole (a tunnel connecting spatially separated regions of space-time) and give one mouth of the wormhole a substantial velocity with respect to the other. Passage through the wormhole would then allow travel to the past.
"Easily said--but where does one obtain a wormhole? Although the theoretical properties of wormholes have been extensively studied over the past decade, little is known about how to form a macroscopic wormhole, large enough for a human or a spaceship to pass through. Some speculative theories of quantum gravity tell us that space-time has a complicated, foamlike structure of wormholes on the smallest scales--10^-33 centimeter, or a billion billion times smaller than an electron. Some physicists believe it may be possible to grab one of these truly microscopic wormholes and enlarge it to usable size, but at present these ideas are all very hypothetical.
REF: ASK THE EXPERTS : PHYSICS
According to current physical theory, is it possible for a human being to travel through time?
Cassandra Kelly
Kanata, Ontario, Canada ]
If the first time travel structure is like a wormhole, it is based in mass: positive mass structure. and to return as the positive mass structure.
The negative mass structure mechanism
As the wormhole is a negative mass structure model. the L-S-E wave is a hole model like the wormhole, in its inside wall, there are some negative mass to lead the speed fast light. It is the l-s-e wave to fast the light mechanism. The base wormhole genreators side should be two L-S-E generators to pass the L-S-E wave, as the safety reason, it is not to pass the earth. As the negative mass action, it is bent ease, and to pass some mass is ease, in future, some satellites is ease to send to the everywhere in sun systems. It is a plan to travel exceed light ease only.
To travel in time is a another question. that will be to rise or down the dimension first. ref the rising and down dimension mechanism in the title:For colour question by HEY.LIKE, that should more than 6 L-S-E generators for time dimension to inside and return from the different time spaece unit. If the time travel is ease, naturely it is fast than light first. It is ease to sent a satellaite to the near sun star, evenif it is far away 11 light-years. The true galaxy time will come belong the humans.
After time travel, A Bosom friend after brings a distant land near.
  • · Replies 21 ·
  • · Replies 95 ·
  • · Replies 17 ·
  • · Replies 125 ·
