Education Advisor
- 2,900
- 2,357
kelly0303 said:Thank you for your reply. How should I do time normalization? Assuming I have 1 count in 0.01 seconds and 1 count in 0.02 seconds, should I normalize by taking 2 counts in 0.02 seconds and 1 count in 0.02 seconds, getting an average of 1.5 counts in 0.01 seconds? I am not sure if I can just multiply the counts by 2 (or any integer). That 1 count is the result of a Poisson process so I am not sure that having 1 count in 0.01 seconds implies 2 in 0.02 seconds.
This is a problem with low or zero counts. For zero counts does that mean actual zero counts or you didn't count long enough? In calculating a rate for very low counts for a short time you have a large error. One count in 0..01 seconds gives a rate of 100 cps ±100 cps as you know and adding such data only makes the total error worse. That is why I think adding counts in a bin and dividing by the total time for that bin is better(and more correct). The more points in a bin the more confidence you have in the numbers. IMO.
Your example of adding rates in a bin vs calculating a rate from the total bin counts divided by the total time you ignored that the latter method produces an average count rate in the bin. To properly compare you need to average the former by dividing the summed rates by the number of them. Thus in your example you should compare 55 to 40. But you say see they do not agree. So what is the problem? Well first you assumed that the two rates where partially concurrent. 100 cps happening at the same time 10 cps for 10 sec. In fact this is not true. They are sequential 100 cps for 10 sec followed by 10 cps for 20 sec. So the whole interval is 30 sec. How do you average this? you take the time weighted average. 100 cps for 1/3 of the time and 10 cps for 2/3 of the time. Summing these you get 40 cps. This is the same reasoning you would use for averaging the rate of a pulsed signal.
