How to Calculate Gravitational Acceleration on a Planet with Core and Shell?
7 replies · 4K views
jrw
I am trying to figure out a gravitational acceleration of a planetary surface with two parts; a core and shell, radius and densities for each are given. I am not sure which equation to use to get started, will I find the gravitational acceleration of the core and then the shell? I just am not sure where to start off. Thanks for any advice that can be shared.
Astronomy news on Phys.org
Well, by Newton's shell theorem you know that you can consider the entire planet to be a simple point mass at the center. So one way to solve the problem would be to compute the total mass, that is core + shell, and use this to solve for gravitational acceleration on the surface from the familiar equation.
jrw said:
but how do I account for the density change?
If you are just concerned about the surface gravity and your planet is spherical, you don't have to.
I guess then I am confused on which density I should use. I am given only the density and radius, so I found the volume of the planet using the total radius, but then to find the mass I need density * volume right?
You use both densities. You have to find the mass of the core and shell separately, and then sum them together to find the total mass.
Oh I see thank you very much :)
