How to Calculate Maximum Speed on a Banked Corner?
  • Thread starter Thread starter shad0w0f3vil
    Maximum Speed
11 replies · 3K views
shad0w0f3vil
Hi, not sure if this is the right section for this question, but I had better try. Anyway, the question is:
Show that the maximum speed on a banked corner where the coefficient of friction between the road and tyres is 0.8 for dry roads and 0.3 when wet:
v=sqrt[(rg(sin(theta) + mu cos (theta)))/(cos(theta)-mu sin(theta))]
where r= the corner radius, mu = the coefficient of friction, theta = the angle of banking
I am unsure of how to approach this. Any advice would be appreciated.
Thanks
Thanks
I would start with some basic assumptions. Firstly, model the car as a particle; secondly, assume that whilst cornering the particle follows a circular path. And finally, assume that the car's vertical position remains constant.
Now, identify all the forces acting on the car and use the assumptions stated above to determine what the constrains are on those forces.
Alright so you know that the friction provides your centripetal force. So what condition will your system be in, such that the centripetal force is overcome and the car skids?
I think you should get it ;)
I have got expressions for the magnitude of both the velocity and acceleration. But I am confused when it comes to finding Nsin(theta) [normally equals ma] and Ncos(theta) [normally equals [mg]. I am just unsure of how to work friction into there. Any ideas?
White Space
shad0w0f3vil said:
Nsin (theta) > Ncos (theta)?
I'm guessing I am wrong? Any help would be appreciated thanks
You're on the right lines, but not quite there yet. As Physicsnoob93 has said, the frictional force provides the force required for the centripetal acceleration. In other words, the centripetal force must be equal to the frictional force for the car to continue traveling around the corner without skidding.
Can you write the above in the form of an equation?
If a=v^2/r and the frictional force provides the required force for the centripetal acceleration, then:
mu.N=v^2/r
Is that what you meant?
mu.N is the force provided by friction whereas (v^2)/r is an acceleration. Remember the centripetal force is a force.
i solved the equation, many thanks to physicsnoob93 and hootenanny
