How to calculate measurement error by using other quantities?
The discussion revolves around calculating measurement error in the context of the equation ##F=mg \tan \alpha##, where participants explore methods for determining the uncertainty in the force ##F## based on known uncertainties in mass ##m## and angle ##\alpha##. The conversation includes both theoretical and practical aspects of error propagation.
  • One participant presents the equation ##F=mg \tan \alpha## and seeks guidance on calculating ##F## with given uncertainties in ##m## and ##\alpha##.
  • Another participant suggests that the uncertainty in ##m## is significant enough that other errors may be negligible.
  • There is a proposal to calculate total measurement error using two different formulas, both of which are later challenged by other participants.
  • Participants discuss the derivative of ##\tan \alpha## and its implications for error calculation.
  • A later reply emphasizes the use of partial derivatives in the general formula for uncertainty, providing a specific example with numerical values.
  • One participant mentions the BIPM guidelines for uncertainty and measurement, suggesting a linearization approach and cautioning about correlations in random variables.
Participants express disagreement regarding the correct formulas for calculating measurement error, with no consensus reached on the appropriate method. Some participants advocate for using partial derivatives, while others propose simpler methods based on prior learning.
Participants acknowledge limitations in their approaches, such as the lack of familiarity with partial derivatives and the potential impact of large uncertainties relative to principal values. There is also mention of the need to consider correlations among variables.
This discussion may be useful for students and practitioners interested in measurement error analysis, particularly in physics and engineering contexts where uncertainty quantification is critical.
Lotto
TL;DR
When I measure some quantities and then want to calculate an another quantity using these ones (I have determined their measurement error) how to do it in general?
Let's say I have ##F=mg \tan \alpha## and want to calculate ##F##. I know ##m=(1.0 \pm 0.5)\,\mathrm{kg}## and ##\alpha=(20.5 \pm 0.5)° ##. How to calculate ##F=( 3.7 \pm ?)\,\mathrm N##? What is the general method of determining a measurement error in these cases?
Hi,
With a 50% uncertainty in ##m##, all other errors are unimportant.
For other cases, check here
BvU said:
Hi,
And can I determine the total measurement error as ##\sigma_F=\sqrt {\left(\frac Fm {\sigma_m}\right)^2+\left(\frac {F}{\alpha} {\sigma_{\alpha}}\right)^2}##? Or ##\sigma_F=\sqrt {\left(\frac Fm {\sigma_m}\right)^2+\left(\frac {F}{\sin \alpha} {\sigma_{\sin \alpha}}\right)^2}##?
Neither of the two is correct. What is the formula to use ?
And what is the derivatve of ##\tan\alpha## ?
My fault, I meant ##\tan \alpha## in the second equation. And I think I could do it this way, since we did at school this for instance: ##\sigma_{\rho}=\sqrt {\left(\frac {\rho}{m} {\sigma_m}\right)^2+\left(\frac {\rho}{V} {\sigma_V}\right)^2}##. I know that the general formula contains partial derivatives, but we haven't done them, so I try to do it like at school.
Then it's a bit awkward indeed! Kudos for trying.
What I meant was that the general formula is indeed $$\sigma_f^2 = \left (\partial f\over \partial m\right )^2 \sigma_m^2 + \left (\partial f\over \partial \alpha\right )^2\sigma_\alpha^2$$ and the derivative of ##\tan\alpha## is ##{1\over \cos^2\alpha}\ ## as in the examples.
with your values ##\sigma_m = 0.5## kg and ##\sigma_\alpha = {0.5\over 180}\pi##, so that the term ## \left (\partial f\over \partial m\right )^2 \sigma_m^2 ## is 350 times bigger than the term ## \left (\partial f\over \partial \alpha\right )^2\sigma_\alpha^2## .
For small ##\alpha## we have ##\tan\alpha\approx\alpha## which yields your first expression in post #3.
(the second expression can be seen to be incorrect: it blows up for ##\alpha\downarrow 0## :wink: )
Either way (thorough or approximation) is no better than completely ignoring the 2.5% ##\sigma## in ##\alpha## opposite the 50% ##\sigma## in ##m##.
The recommended procedure is outlined in the BIPM (International Bureau of Weights and Measures) "Guide to Uncertainty and Measurement". In very general terms, one would typically linearise the function about the expectation and compute the uncertainty/variance using the appropriate linear transformation of variable.
In cases where the uncertainty is large relative to the principal value, you will need to use a second order (or higher) expansion and things get a bit more complicated.
Also, you need to be mindful of correlations that might be present in your random variables. The wiki page on "variance" gives a good summary on how to separate correlated variables.
  • · Replies 18 ·
  • · Replies 21 ·
