How to calculate rebound speed of ball hitting a wall?
The discussion focuses on calculating the rebound speed of a ball after it collides with a wall, specifically a ball with a mass of 0.075 kg traveling at 2.20 m/s. It is established that 20% of the ball's initial kinetic energy is dissipated during the collision. The correct rebound speed is determined to be 1.97 m/s, derived from the remaining 80% of the initial kinetic energy, calculated using the formula for kinetic energy, KE = 1/2 mv².
  • Understanding of kinetic energy calculations (KE = 1/2 mv²)
  • Basic knowledge of impulse and momentum concepts
  • Familiarity with energy conservation principles
  • Ability to manipulate algebraic equations
  • Study the principles of energy conservation in collisions
  • Learn about impulse and its relation to momentum
  • Explore examples of elastic and inelastic collisions
  • Investigate the effects of energy dissipation in real-world scenarios
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for practical examples of collision problems.
MattDutra123
A ball of mass 0.075 is traveling horizontally with a speed of 2.20 m/s. It strikes a vertical wall and rebounds horizontally. Due to the collision with the wall, 20% of the ball's initial kinetic energy is dissipated.
Show that the ball rebounds from the wall with a speed of 1.97 m/s.
Impulse = F*t
Kinetic Energy = 1/2mv2
I attempted to use conservation of energy by having the initial kinetic energy (0.075*2.202) be equal to 20% final kinetic energy (0.075*v2*1/5) This gave me a result of 2.2 m/s. I don't know how to reach the desired result of 1.97 m/s.
Apologies in advance for bad formatting.
That means 20% was lost.
That would be the ball gaining energy, ending with five times what it had to start with.
That would be the ball gaining energy, ending with five times what it hard to start with.
So if I divide the right hand side by 1/5 as opposed to multiplying it as I did, would my approach work?
No, because the final energy is not 1/5 of the initial energy.
It lost 20% of its energy. That means 80% is left. The final energy is 80% of the original energy.
Thank you. Very basic misunderstanding.
  • · Replies 17 ·
