How to Calculate the Moment of Inertia of a Thin Rod About an Off-Center Axis?
  • Thread starter Thread starter GreatEscapist
    Axis Moment
The discussion revolves around calculating the moment of inertia for a thin rod of mass M and length L about an axis located a distance d from one end. Participants are exploring the integration method required to solve this problem.
  • The original poster attempts to set up the problem using integration, considering the moment of inertia formula and the need to account for mass distribution on both sides of the axis. Some participants question the use of different densities in the integrals and suggest that the integration should cover the total length of the rod.
Participants are actively discussing the setup of the integrals and the assumptions made regarding density. There is a recognition of the need for clarity in the integration limits and the implications of using different densities. Some guidance has been offered regarding the integration process, but no consensus has been reached on the correct approach.
There is a concern about the dimensional correctness of the densities used in the integrals, and participants are reflecting on the implications of integrating over the entire length of the rod versus segments. The urgency of the homework deadline is also noted.
GreatEscapist
Calculate by direct integration the moment of inertia for a thin rod of mass M and length L about an axis located distance d from one end.
I = Ʃmir2i
Which can be rewritten as int (r2)dm as Δm -> 0
Since we cannot integrate over a mass, we need to switch to dx, which is dm = M/L dx
The question is asking us to find the moment of inertia as it rotates on an axis d from one end.
Normally, if we are trying to find the moment of inertia of an "infinitely thin" rod rotating on one end, the moment of inertia is (1/3)ML2
However, we have to manually integrate this problem because we have mass on both sides of the axis of rotation.
I took two integrals- one on one side of d, and on the other.
First side:
(M/d) int(x2)dx (with bounds 0 to d)
(M/d)(x3/3) (with bounds 0 to d)
= Md2/3
The second side:
(M/L-d) int(x2) dx (with bounds from d to L)
(M/L-d) (x3/3) (with bounds from d to L)
(M/L-d) ( (L3/3) - (d3/3))Then I added the two moments of inertia together, to get:
(Md2/3) + (M/L-d)((L3/3) - (d3/3))
This answer is not correct, and I was wondering where i went wrong conceptually/mathematically. Homework is due soon, so any immediate help is greatly appreciated.
I = Ʃmir2i
First side:
= Md2/3
The second side:
The density is M/L. Why did you use M/d and M/L -d as density? The second one is even dimensionally wrong.
You should integrate simply from -d to L-d.
ehild
I thought you used d and L-d because that was the length over which you were integrating.
It's always just over the total length?
The density of both pieces are the same M/L.
You are supposed to get the moment of inertia by direct integration of the square of the distance from the pivot from one end to the other one. You can replace one integral with the sum of other two, but why?
ehild
Thank you! I understand a bit better now.
this did not help at all lol. so no one knows the answer?
Why do you think that the thread was no help? What is your question?
Read the Forum rules. We must not not give out full solutions.
ehild
  • · Replies 28 ·
  • · Replies 21 ·
11K
