How to Calculate the Sum of Fermionic Operator Products?
  • Thread starter Thread starter LagrangeEuler
    Operators Sum
The discussion revolves around calculating the sum of products of fermionic operators, specifically involving the vacuum state and the action of creation and annihilation operators. The context is rooted in quantum mechanics and the properties of fermions.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants explore the meaning of the vacuum state and the role of fermionic operators. Questions arise regarding the normalization of states and the implications of the anti-commutation relations of the operators.
There is an ongoing exploration of the properties of the vacuum state and the effects of applying creation and annihilation operators. Some participants suggest that the normalization of states is typically expected, while others question the necessity of certain assumptions regarding the inner products of states.
Participants are discussing the implications of anti-commutation relations and the requirement to normal order operators in the context of fermionic systems. There is also a focus on the interpretation of the vacuum state and its representation in the problem.
LagrangeEuler
How to calculate?
## \sum _{i,j} \langle 0|\prod_n \hat{C}_n \hat{C}^+_i\hat{C}_j \prod_n \hat{C}^+_n|0 \rangle ##
##\hat{C}^+, \hat{C}## are fermionic operators.
##\{\hat{C}_i,\hat{C}^+_j\}=\delta_{i,j}##
I have a question. What is ##|0 \rangle##? Is that maybe ##|0 0\rangle##?
Are the [itex]\hat{C}[/itex]'s ladder operators?
Presumably you have some number of Fermions, ##N##. Then, ##\left| 0 \right\rangle## represents the vacuum state which contains no Fermions - you can take it as a shorthand for
$$\underbrace{\left| 0 0 \dots 0 \right\rangle}_{N~\rm{terms}}.$$
So, the Fermion creation operator for the kth fermion when acting on this state will create a Fermion in the kth slot of the vacuum state (changing the 0 to a 1).
That is,
$$\hat{c}_k^\dagger \left| 0 0 \dots 0_k \dots 0 \right\rangle = \left| 0 0 \dots 1_k \dots 0 \right\rangle,$$
where I used a subscript ##k## to denote that that is the kth entry in the state.
Tnx.
##c^+_k|00…0k…0\rangle=|00…1k…0\rangle##
and is maybe
##c^+_k|00…1k…0\rangle=0?##
Then
##\prod_n c^+_n |000...0\rangle=|111...1\rangle##
So result is
## \sum_{i,j}\langle 1111...|\hat{C}^+_i\hat{C}_j|111...\rangle=\sum_{i,j}\delta_{i,j}?##
LagrangeEuler said:
So result is
That's what it looks like to me. Note that since you're summing over i and j you should get a number out at the end.
And is it necessarily to ##\langle 1...1|1...1 \rangle## be ##1##?
this is a problem in anti commutation. Anti commute the annihilation operators past all the other operators so that they may annihilate the vacuum, in other words you have to normal order the operators
While not strictly necessary, typically the wavefunctions are defined to be normalized, no?
  • · Replies 0 ·
