How to Calculate Ultrasound Power from Float Displacement?
  • Thread starter Thread starter bobred
    Float
The discussion revolves around calculating ultrasound power based on the displacement of a submerged float held in equilibrium by hanging chains. The float's downward displacement is said to be proportional to the ultrasound power applied to it, and participants are exploring how to express power as a function of this displacement.
  • Participants are attempting to relate the float's displacement to the force exerted by the chains. Questions arise about how to calculate the loss of weight of the chains as the float is displaced. There is also a suggestion to approximate the chain's configuration to simplify the analysis.
The discussion is ongoing, with participants clarifying their understanding of the relationship between float displacement and the forces involved. Some guidance has been offered regarding approximating the chain's shape, but no consensus has been reached on the method to calculate the power function.
Participants note that the problem involves a specific application of physics that may not be familiar to everyone, indicating a potential barrier to understanding the relevant equations and concepts.
bobred
There is a submerged float which is held in equilibrium by three hanging chains (see attached), a portion of the chain hangs below the float. Ultrasound directed onto the top face of the float (which is concave with angle α) and the float is displaced downward proportional to the ultrasound power. Find the power as a function of displacement.
Power W=\frac{Fc}{2\cos^2\alpha}
Where F is the force and c is the speed of sound in water
I need to relate the distance of the float displacement to the Force.
As it is displaced the weight of the chain decreases. Linear density is mass over length, I know the length of the chains and their masses, all the same.
How do I work out the loss of weight?
The whole set up, and the quoted relevant equation, appear to relate to some relatively obscure branch of physics. Most people on this forum would, like me, have no idea about the application of that equation.
But maybe that's not what you are asking. Are you just asking how to relate the change in depth of the float to the change of force on it from the weight of the chains?
If so, I suggest you approximate each chain as two vertical sections joined by a U-shaped portion of constant size. Otherwise, you can look up 'catenary'.
Hi, yes I'm asking how to relate the change in depth of the float to the change of force on it from the weight of the chains.
Did you understand my suggestion?
Looking into it now thanks.
12K
  • · Replies 29 ·
11K
