How to Choose Between FDTD, FEM and MoM | Open-Source Codes
  • Thread starter Thread starter martindmaas
    Fdtd Fem
Choosing between FDTD, FEM, and MoM for electromagnetic simulations involves considering the specific requirements of the model, such as size and dimensionality, with FDTD being suitable for large models, FEM for 3D structures, and MoM for 2D planar designs. Users of commercial software often cite the limitations of open-source tools, such as incomplete models and interoperability issues with industry standards, which can hinder collaboration. While MoM can provide faster results, it may struggle with complex geometries and higher frequency effects, necessitating careful setup to avoid inaccuracies. The discussion highlights a trade-off between computational efficiency and simulation accuracy, especially in sensitive applications. Ultimately, the choice of simulation method depends on the specific project needs and available resources.
martindmaas
TL;DR Summary
How to choose between FDTD, FEM and MoM for Electromagnetic Simulations, discussion about Open Source Software.
Hi,
I've just written an article about how to choose between FDTD, FEM and MoM for Electromagnetic Simulations, and also with brief reviews of some of the best Open Source alternatives out there.
https://www.matecdev.com/posts/differences-fdtd-fem-mom.html
I've seen that in this forum many people seem to be using commercial simulation software. Just wondering... Are you using this commercial software because open-source codes fall short in some regards?
Thanks for sharing your view!
Welcome to PF. :smile:
Interesting article and blog site. I'll have to spend some more time reading through it.
Likes martindmaas
I think you covered choosing the preferred tool properly. To summarize it I would use time domain simulations on electrically large models; FEM frequency domain for 3D models meaning z-direction has a bigger impact on the results, and MoM for 2D models like planar structures.
I’m not familiar with the open source for these as I only use what my employer provides or authorizes if whatever they have isn’t helping me meet the requirements. I haven’t ran into any major issues with the industry tools and results often align with measured results. I can speak about my experience with open source tools. They are usually incomplete or the models are too basic; they also aren’t friendly with other tools including the industry standard say for instance if I were to need to share my setup or results with a counterpart or different type of engineer using different tools. I would suspect but do not know that the adaptive process (especially meshing) has fast algorithms to help the simulations converge more quickly.
Likes martindmaas and berkeman
Thank you Joshy.
I would be aware of using FDTD in electrically large problems... it could be really computationally expensive. If MoM can also be applied to that problem, it should be a lot faster, if the underlying MoM implementation works correctly.
As for interoperability with industry tools, that's a good point. I believe that could be a weak spot of most open-source tools, indeed. I guess the main issues would be multiphysics integration, and the possibility of writing CAD files as output of the models, am I right?
I opt for 2.5D MoM simulations whenever I can or if I’m only looking for quick qualitative insight, but it becomes less accurate when the geometry is not planar say for instance a connector, via transition, or cavity; also when I’m simulating something more assembled say for instance mounting on a tall pole or on an aircraft. Some tools have some great secret sauce features such has a hybrid type of simulation where it meshes differently in different regions. Try a simulation with two really long lines with side by side via transitions say for instance underneath a BGA and let me know if MoM gives you accurate results on the coupling. You’re going to want the 3D meshing on those via transitions for sure. All of the MoM I’ve worked with are also really difficult to include a lot of higher order effects say for instance something above 10 GHz I’ll probably really want to include skin effect, but have often have to kind of cheat and just manually say the metal is a lower conductivity. I think it’s because when the 2.5D simulation performs mathematical operations there are some assumptions that the 3D transform will be more uniform than it is in real life. Another thing I forgot to mention is sometimes I’m working with really sensitive stuff that I don’t want to share in detail if I don’t have too, and so I wouldn’t want to work with something open source if I want to send an encrypted model to my counterparts.
There’s obviously a tradeoff between computational resources (or time) and accuracy depending on what you’re simulating. If you blindly opt for MoM trying to cut corners for a faster simulation in my BGA example above or a flexible substrate with different zones such as coverlay layer…. sure you’ll save time, which will give you plenty of time to clear your office or cube before your stakeholders come to you. It’s not to say that you cannot achieve correct results with MoM, but it requires a lot more thought and more detailed setup.
Likes martindmaas
There’s obviously a tradeoff between computational resources (or time) and accuracy depending on what you’re simulating. If you blindly opt for MoM in my BGA example above or a flexible substrate with different zones such as coverlay layer…. sure you’ll save time, which will give you plenty of time to clear your office or cube before your stakeholders come to you.
Yes, some or even most of the MoM implementations, can definitively have meshing/convergence issues.
In my research group, we once run a detailed comparison of our research software vs a commercial MoM and found that (probably) the secret sauce in the MoM was leading to wrong solutions and non-convergence, even for a relatively simple geometry. Things like connectors or small gaps in high-frequency problems are major offenders I guess. I guess that open-source software doesn't include the secret sauce so at least it is easier to tell when something isn't working.
Regards!
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
