How to Create a Java Program for Generating Custom Passwords?
  • Context: Comp Sci
  • Thread starter Thread starter Cia
    Generator Java
37 replies · 6K views
Cia
Code:
import java.util.Scanner;
import java.util.Random;
public class Passwords
    public static void main(String[] args)
        Scanner in = new Scanner(System.in);
        Random r = new Random();
        System.out.println("                             Password Generation Menu                ");
        System.out.println("******************************************************************");
        System.out.println("*  [1] Lowercase Letters                                   *");
        System.out.println("*  [2] Lowercase & Uppercase Letters                       *");
        System.out.println("*  [3] Lowercase, Uppercase, and Numbers                   *");
        System.out.println("*  [4] Lowercase, Uppercase, Numbers, and Punctuation      *");
        System.out.println("*  [5] Quit                                                *");
        System.out.println("Enter Selection (1-5): ");
        int choice = in.nextInt();
        System.out.println("Password Length (1-14): ");
        int passwordLength = in.nextInt();
        int randNum = 0;
        String password =  "";
        for (int counter = 0; counter <  passwordLength; counter++)
                 if (choice ==1)
                   randNum =  97 + r.nextInt (26) ;
                  while ( !( (randNum>=97) && (randNum<=122) ))
                       randNum = 97 + r.nextInt (26) ; //generate a new random value
                       //randNum =  (int) (Math.random() * (122 - 97 + 1) ) + 97;
                    }//end while
                   //concatenate new char to the password since the value is in the desired range
                   char letter = (char) randNum;
                       password += letter;
                    else if (choice == 2)
                        randNum = 65 + r.nextInt (58) ;
                      while (!(randNum>=65) && (randNum<=90) || (randNum>=97) && (randNum<=122))
                          password += letter;
                       else if (choice ==3)
                             randNum =  48 + r.nextInt (79) ;
                           while (!(randNum>=65) && (randNum<=90)||(randNum>=97) && (randNum<=122) || (randNum>=48) && (randNum<=57))
                              randNum =  48 + r.nextInt (79);
                               password += letter;
                        else if (choice ==4)
                                 randNum =  48 + r.nextInt (78) ;
                               while( !(randNum>=58) && (randNum<=64)&&(randNum>=48) && (randNum<=67)&&(randNum>=65) && (randNum<=90) &&(randNum>=97) && (randNum<=122))
                               password += letter;
                                   else
                                   System.out.print("Good Bye!");
         }//end of for loop
    System.out.println( "" + "" + password );
    }//end of main method
}//end of class
Cia said:
Code:
        int randNum = 0;
                 if (choice ==1)
                    }//end while
                       password += letter;
                          password += letter;
                               password += letter;
                               password += letter;
                                   else
         }//end of for loop
}//end of class
What's your question? How are you stuck?
When, i select a selection sometimes I get symbols when am not suppose to. Selection 1 is fine but sometimes selection 2-4 are off.
You have lines similar to this for choices 2, 3, and 4.
Code:
The condition above evaluates to true if
1) randNum < 65 AND randNum <= 90,
OR
2) randNum >= 97 AND randNum <=122
Do you see why this is happening? This looks like a copy and paste problem that you didn't think hard enough about.
Code:
OR
Actually, i did think. Its just a java basic class am in now. So, basically you're saying this is happening because of the or symbol? I even tried to use the and symbol but, it still did not come out correctly though
The problem in that line is what the negation "!" is being applied to. By contrast for choice ==1, when you don't really need the while loop at all, you are using it more correctly.
Okay, my teacher wants me to use the while loop. So, should I just take the negation symbol out?
If you don't understand what the negation is doing, you need to find out. The while loop is useful - if the logical expression is correctly written - for the other 3 choices. Again, if you don't understand why, you need to find out and understand what it is doing.
It might be useful all round if you were to describe in English what you are trying to do in, say, the choice==2 section.
I know that the negation means "not". Choice 2 and choice 3 give me symbols when they are not suppose to.
Yes, they will - that is a bug - but can you describe what the intended purpose of the test in the choice==2 while statement is? And remember that the while loop executes as long as that test evaluates to true.
In post #4 I described what makes the conditions true when for choice is 2, 3, or 4. Is that the logic you intended?
So with that begin said I should remove the negation.
Cia said:
So with that being said I should remove the negation.
No. You should clearly express what it is you want the test to do, and change it so that it actually does it.
Removing the negation is a random action, not a debugging step. It will not fix the problem.
It really is important and valuable to take the time to write down exactly what you want that test to achieve.
Well, I know that i want choice 2 to give me lower and upper case letters only. And I know that i want choice 3 to give me lower, uppercase letters and numbers.
Right. So looking at the while loop for choice 2, what is the test doing to achieve that end?
Considering Joffan's question, how should the condition in the while loop be changed?
Code:
Note that you are also going to have to change the logic in the loops for choice == 3 and choice == 4.
Code:
I should probably take the negation out and use the and symbol instead.
:) You won't solve this by guessing at changes.
As a step along the way to specifying the purpose - what do the numbers in that test represent? Describe each of those four comparisons to me.
I actually tried it and it did not work. The numbers represent letters in the ASII table. Actually this is the assignment constructions
  1. Display a menu giving the user a choice of character sets to use to construct the password. (Note: Do not use the first range of punctuation symbols with ASCII values from 33-47).
  2. Allow the user to select the number of characters in the password (at least up to 14).
  3. Create a randomly generated password from the character sets selected by the user.
Tried what? Joffan is asking you to explain what each of the four comparisons in this code:
Code:
In other words, what values of randNum make the first comparison true? Same question for the second comparison. Same question for the third comparison. Same question for the fourth comparison.
Below, yes we get that. Try to focus on what we're asking.
Code:
the randNum for choice 1 is 26. I get this by subtracting 122 from 97 and adding 1. With choice 2, the randNum is 58, 122- 65 +1.
No, randNum is a random number between 65 and 123. That's what your code at the top of the if block is doing. nextInt returns a random number in the range 0...58 in this case, because you're calling nextInt with an argument of 58.
So randNum could be any number in the set {65, 66, 67, 68, ..., 121, 122, 123}
Can you use every number in this set? Not every number in this set is the ASCII code for an uppercase letter or lowercase letter. The four conditions below are supposed to pick out the numbers you can use.
Code:
Code:
I have a question: Should I place randNum = 65 + r.nextInt (58) ; after the while loop? Also, should I change my ranges?
p.s. thanks for being patience with me so far
Let's deal with the conditions first. What has to happen so that randNum's value corresponds to an uppercase letter or a lowercase letter? The password string that you build up should contain only these characters.
The randNum value must be in the two ranges
It can't be in the two ranges - it can only be in the first range or the second range, or neither.
Each of the four comparisons above will evaluate to true or false. To help you understand what your code is doing, please state what each comparison evaluates to for each of the following numbers.
Code:
Number          Comparison 1(T/F)     Comparison 2(T/F)   Comparison 3(T/F)    Comparison 4(T/F)
66
93
101
123
Here's what it seems is intended to happen in each choice block, descriptively:
Java:
          get a random number that can represent any valid character (but maybe also invalid characters)
          while (the number does NOT represent a valid character)
              refresh the random number in the same way as above
          // here we have left the while loop, so the number must now represent a valid character
          turn the number into a character
          append the character onto the password
What we are trying to help you do is learn to write that 'while' test properly.
Code:
66                        f
93                        t
101                     f
123                     t
