How to decompose the following expression?
  • Level: Graduate
  • Thread starter Thread starter Alec V
    Expression
11 replies · 3K views · last reply
Alec V
This comes from one of the research papers that I'm reading. The authors decompose Eq. 1 and obtain Eq. 2. After several attempts, I have been fairly unsuccessful at obtaining Eq. 2 from Eq. 1.
I have tried using partial fractions decomposition without much success. Any help would be greatly appreciated.
Eq. 1
20-%20%5Cfrac%7B%5Cprod_%7Bs2%7D%20%7D%7B1-%5Cdelta%20+%5Cdelta%20%5Cepsilon%20_%7Bs2%7D%7D.gif
Eq. 2
Thanks!
Mathematics news on Phys.org
Try to find the other direction, that is easier (and all steps work both ways). You can simplify equation 2 and get equation 1.
Alec V said:
Eq. 2
You have to explain the relations that exist among the symbols to get help on this question.
Alec V said:
Eq. 2
Yes, especially ##\Pi_{s1}## and ##\Pi_{sS2}##. Are they just numbers or is something else going on? The symbol ##\Pi## is usually used to denote a product.
Sorry, I should have clarified. ∏s1 is profit in country 1, ∏s2 is profit in country 2, ∈s1 is risk in country 1, ∈s2 is risk in country 2, and δ is the discount rate.
Eq. 2 tries to separate risk elements (∈s1 and ∈s2) from the profit gap between countries. Hope this helps.
∏ as variable is a bit unusual, but as long as all symbols are just variables, their meaning does not matter. This just needs the basic rules to work with fractions.
The results of a simple numerical test did produce identical answers for EPV. (Of course someone should check my program.)
#include <stdio.h>
#include <math.h>void main()
{double pi_1, pi_2, delta, ep_1, ep_2;
double frac1,frac2, numerator, denom1, denom2;
double epv_1, epv_2;
pi_1 = 10.0;
pi_2 = 30.0;
delta = 0.25;
ep_1 = 6.0;
ep_2 = 5.0;
printf("pi_1 = %6.3f pi_2 = %6.3f delta = %6.3f ep_1 = %6.3f ep_2 = %6.3f\n\n",pi_1,pi_2,delta,ep_1,ep_2);
denom1 = 1.0 - delta + delta * ep_1;
frac1 = pi_1/denom1;
printf("frac1 %6.4f\n", frac1);
denom2 = 1.0 - delta + delta * ep_2;
frac2 = pi_2/denom2;
printf("frac2 %6.4f\n",frac2);
epv_1 = frac1 - frac2;
printf("epv_1 = %6.3f\n\n",epv_1);
frac1 = (pi_1 - pi_2)/ (1.0 - delta);
frac2 = ( delta * ( denom1 * ep_2 * pi_2 - denom2 * ep_1 * pi_1) )/ ((1.0 - delta)*denom1* denom2 );
epv_2 = frac1 + frac2;
printf("epv_2 = %6.3f\n", epv_2);}
The output
pi_1 = 10.000 pi_2 = 30.000 delta = 0.250 ep_1 = 6.000 ep_2 = 5.000
frac1 4.4444
frac2 15.0000
epv_1 = -10.556
frac1 -26.6667
frac2 16.1111
epv_2 = -10.556
Getting rid of terms in a denominator that don't cancel with anything in the numerator is a frequent mathematical daydream. Suppose we approach the problem as the desire to express:
[itex]( \frac{A}{W + F} - \frac{B}{W + G})[/itex] as [itex]( \frac{A}{W} - \frac{B}{W}) \ + \ L[/itex]
where [itex]L[/itex] is the leftover stuff.
Then
[itex]L = \frac{A}{W+F} - \frac{A}{W} - \frac{B}{W + G} + \frac{B}{W }[/itex]
[itex]= \frac{ AW - A(W+F)} {W(W+F)} + \frac{-BW+B(W+G)}{W(W+G)}[/itex]
[itex]= \frac{-AF}{W(W+F)} + \frac{BG}{W(W+G)}[/itex]
[itex]= \frac{1}{W} ( \frac{BG}{W+G} - \frac{AF}{W+F})[/itex]
In the problem at hand, there are relations between [itex]W, F, G[/itex]
[itex]W = 1 -\delta[/itex]
[itex]F = \delta \epsilon_1 = (1-W)\epsilon_1[/itex]
[itex]G = \delta \epsilon_2 = (1-W)\epsilon_2[/itex]
Substituting in selected places for [itex]F[/itex] and [itex]G[/itex]
[itex]L = \frac{1}{W}( \frac{B(1-W)\epsilon_2}{W+G} - \frac{A(1-W)\epsilon_1}{W+F} )[/itex]
[itex]= \frac{1-W}{W} ( \frac{ \epsilon_2 B}{W+G} - \frac{\epsilon_1 A}{W+F})[/itex]
[itex]= \frac{1-W}{W} ( \frac{ (W+F)\epsilon_2 B - (W+G)\epsilon_1A}{(W+G)(W+F)})[/itex]
In the problem at hand:
[itex]A = \prod_{s1}[/itex]
[itex]B = \prod_{s2}[/itex]
[itex]W = (1 -\delta)[/itex]
[itex]F = \delta \epsilon_{s1}[/itex]
[itex]G = \delta \epsilon_{s2}[/itex]
[itex]\epsilon_1 = \epsilon_{s1}[/itex]
[itex]\epsilon_2 = \epsilon_{s2}[/itex].
Then
Thanks so much! The simplification of L makes sense. Could you please dwell on how to separate [itex]( \frac{A}{W} - \frac{B}{W})[/itex] from [itex]( \frac{A}{W + F} - \frac{B}{W + G})[/itex]?
I'm not sure what you are asking.
So, we expressed [itex]( \frac{A}{W + F} - \frac{B}{W + G})[/itex] as [itex]( \frac{A}{W} - \frac{B}{W}) \ + \ L[/itex]. You then proceed to further simplify the leftover stuff. However, how can we get from [itex]( \frac{A}{W + F} - \frac{B}{W + G})[/itex] to [itex]( \frac{A}{W} - \frac{B}{W}) \ + \ L[/itex]?
Thanks.
I just defined [itex]L[/itex] to be [itex]( \frac{A}{W + F} - \frac{B}{W + G}) - ( \frac{A}{W} - \frac{B}{W})[/itex]
