How to derive an average output from a triaxial accelerometer
TS@QS
Hi
I am measuring the acceleration of an oscillating body with a triaxial accelerometer. I want to derive some kind of vector average of the 3 channel output. Someone suggested using
x= √(a squared + b squared + c squared)
... where x is the vector average and a, b and c are the accelerometry readings for each channel. Someone else told me that this isn't ideal but I don't really understand why not. Please help - is it better to just take the mean of all 3... or even just to choose the largest amplitude channel and use that?
Thanks
I think your method is just fine, kind of depends on what your needs are. You lose the "sign" of the acceleration with that method, just results in a magnitude. You could also look at the min and max values, or min and max amplitudes on each channel.
thanks - well , I'm using the acceleration as a surrogate for amplitude of displacement. I want to compare the oscillatory movement before and after applying a damping system to decide if there is an 'average' damping effect overall.
Since you are just looking for a relative change, looking at the highest amplitude channel probably works fine. Acquire all the data you can, then mine it for whatever looks most useful.
thanks, I'll try that.
I was just wondering why i was told that there are better more sophisticated methods and what these could feasibly entail?
You could certainly get into looking at impulse and frequency response for different damping. Vibrational response is a whole field in and of its own.
