How to derive the associated Legendre equation
10 replies · 3K views · last reply
davidge
How does one arrive at the equation
$$\bigg( (1-z^2) \frac{d^2}{dz^2} - 2z \frac{d}{dz} + l(l+1) - \frac{m^2}{1-z^2} \bigg) P(z) = 0$$
Solving this equation for ##P(z)## is one step in deriving the spherical harmonics "##Y^{m}{}_{l}(\theta, \phi)##".
The problem is that the book I'm following doesn't show how to arrive at the above equation. It shows how to arrive at it only for the special case ##m=0##.
I've tried googling "Associate Legendre's equation" and "Legendre's general equation derivation" but it seems there's no such derivation on web.
Are you trying to solve the hydrogen atom eigenfunction?
As a matter of fact, that differential equation is the defining equation for the associated Legendre polynomial. Therefore, unless you encounter it in a different context, there is no way to derive it. It is simply defined such that the associated Legendre polynomial is the solution of that equation.
The standard way to derive the equation is to apply the separation ansatz
$$\psi(r,\vartheta,\varphi)=R(r) \Theta(\vartheta) \Phi(\varphi)$$
for the eigenfunctions of the Laplacian in spherical coordinates.
$$\Delta \psi=\frac{1}{r} \partial_r^2 (r \psi) + \frac{1}{r^2 \sin \vartheta} \partial_{\vartheta}(\sin \vartheta \partial_{\vartheta} \psi) + \frac{1}{r^2 \sin^2 \vartheta} \partial_{\varphi}^2 \psi.$$
I'm trying to derive the spherical harmonics functions, often denoted by ##Y^{m}{}_{l}(\theta, \phi)##. It's part of the hydrogen atom problem.
Maybe I should have put my question in the following way
The book I'm reading shows how to arrive at the equation $$\bigg( (1-z^2) \frac{d^2}{dz^2} - 2z \frac{d}{dz} + A - \frac{m^2}{1-z^2} \bigg) P(z) = 0$$
where one needs to find what ##A## is. The book shows how to find ##A## for the case ##m=0##; it's ##A = l(l+1)##. Then it states that ##A = l(l+1)## even for ##m \neq 0##, but does not proves that, as it proves for the former case.
@vanhees71 By doing this way, can one show that ##A = l(l+1)## is the correct term?
If I think about it, an even simpler way is to look for harmonic functions, i.e., the Laplace equation
$$\Delta \psi=0.$$
You make the above separation ansatz. Plugging it into the Laplace Equation leads to
$$\frac{\Theta \Phi}{r} (r R)''+\frac{R \Phi}{r^2 \sin \vartheta}(\sin \vartheta \Theta)'+\frac{R \Theta}{r^2 \sin^2 \vartheta} \Phi''=0.$$
Multiply the entire expression with ##r^2/(R \Theta \Phi)##, and you get
$$\frac{r}{R} (r R)''=-\frac{1}{\Theta \sin \vartheta}(\sin \vartheta \Theta)'-\frac{1}{\Phi \sin^2 \vartheta} \Phi''.$$
Sine the left-hand side depends on ##r## only but the right-hand side on ##\vartheta## and ##\varphi## the entire expression must be some constant ##A##:
$$r (r R)''=A R.$$
The equation can obviously solved by the ansatz ##R=c r^{\lambda}##:
$$r (r R)''=c r (r^{\lambda+1})''=c r (\lambda+1) \lambda r^{\lambda-1}=c A r^{\lambda} \; \Rightarrow\; \lambda(\lambda+1)=A.$$
Then you repeat the argument with the right-hand side
$$-\frac{1}{\Theta \sin \vartheta}(\sin \vartheta \Theta)'-\frac{1}{\Phi \sin^2 \vartheta} \Phi''=\lambda(\lambda+1)$$
or, a bit rewritten,
$$-\frac{\sin \vartheta }{\Theta}(\sin \vartheta \Theta')' - \lambda(\lambda+1) \sin^2 \vartheta = \frac{1}{\Phi} \Phi''=-m^2,$$
where again ##m=\text{const}## since the left-hand side depends on ##\vartheta## only and the right-hand side on ##\varphi## only. You then find
$$\Phi(\varphi)=\exp(\mathrm{i} m \varphi),$$
and since the solution should be a ##2 \pi##-periodic function in ##\varphi## you get ##m \in \mathbb{N}##.
Finally you are left with [Typos corrected]
$$\sin \vartheta (\sin \vartheta \Theta')'+ \left [\lambda(\lambda+1) \sin^2 \vartheta - m^2 \right ]\Theta=0.$$
Now substitute
$$z=\cos \vartheta, \quad \Theta(\vartheta)=P(z).$$
From this you get immediately your formula.
PeterDonis said:
Which book?
McIntyre - Quantum Mechanics - A Paradigms Approach
@vanhees71 Perfect. Thank you.
Is there a typo here?
$$-\frac{\sin \vartheta }{\Theta}(\sin \vartheta \Theta')' - \lambda(\lambda+1) \sin^2 \vartheta = \frac{1}{\Phi \sin^2 \vartheta} \Phi''=-m^2,$$
$$ \Longrightarrow -\frac{\sin \vartheta }{\Theta}(\sin \vartheta \Theta)' - \lambda(\lambda+1) \sin^2 \vartheta = \frac{\Phi''}{\Phi}=-m^2$$
And, also, here?
$$\sin \vartheta (\sin \vartheta \Theta')'+ \left [\lambda(\lambda-1) \sin^2 \vartheta + m^2 \right ]\Theta=0.$$
$$ \Longrightarrow \sin \vartheta (\sin \vartheta \Theta)'+ \left [\lambda(\lambda+1) \sin^2 \vartheta - m^2 \right ]\Theta=0.$$
vanhees71 said:
I've corrected the typos in #6. I hope, now all signs are correct ;-).
You are still keeping the derivative symbol on ##\Theta##. Is this so?
Also, you have actually forgotten the first one that I have pointed out.
Argh. Yes, I corrected it, but the ##\Theta'## must stay. You have a 2nd-order differential operator (it's more or less ##\hat{\vec{L}}^2##, and it's much more understandable what's coming out using the semi-algebraic way in my QM manuscript).
