How to determine ##\psi(x,0)## in general situation?
  • Context: Undergrad
  • Thread starter Thread starter Kim hyeon su
    General
This discussion focuses on determining the wave function ##\psi(x,0)## for free particles in various situations where it is not explicitly provided. It highlights that ##\psi(x,0)## can be experimentally determined, but requires measurements across the entire range from ##-\infty## to ##+\infty##. The conversation also distinguishes between different types of wave functions, such as those for particles in infinite square wells and harmonic oscillators, emphasizing the necessity of knowing the Hamiltonian to solve Schrödinger's equation effectively.
  • Understanding of Schrödinger's equation and its applications
  • Familiarity with wave functions and their properties
  • Knowledge of Hamiltonian mechanics in quantum systems
  • Experience with quantum mechanics concepts, particularly free particles
  • Study the derivation and solutions of Schrödinger's equation for various potentials
  • Research experimental techniques for measuring wave functions in quantum mechanics
  • Explore the characteristics of wave functions in infinite square wells and harmonic oscillators
  • Learn about the implications of the Dirac delta function in quantum measurements
Students and researchers in quantum mechanics, physicists working with wave functions, and anyone interested in the theoretical aspects of quantum particle behavior.
Kim hyeon su
TL;DR
I want to know how can we determine ##\psi(x,0)## in a general situation.
First of all, please understand that I am not good at English so I used the translator.
(EDITED by mentor: small edits + added latex...)
After I studied free particles, I wanted to apply what I learned to other situations.
But as you know, to determine the solution of the free particle, you need to have ##psi(x,0)##. Usually, ##psi(x,0)## is given by the textbook problem (like: ##psi(x) = A e^{-x²}##).
However, in other situations (not in the book), there no information is given about psi(x,0).
So I want to know how can we determine ##psi(x,0)## in a general situation.
1) if ##\psi(x,0)## is determined by experiment, we have to measure ##-\infty## to ##+\infty##? How?
2) What kind of ##\psi(x,0)## can a free particle have? And what makes them different?
The value of the wave-function ##\psi(x,0)## is not something that is measured, that is except for the case where the particle being described has been observed at a single point in which case the wave-function is a Dirac delta function centered at that point.
Typically one instead, solves the differential equation (Schrödinger's equation) for the wave function satisfying certain conditions. One typically must know the Hamiltonian (defining the system energy and time evolution via Schrödinger's eqn) and assume, for example the particle has a well defined energy.
Typical examples are things like a particle in an infinite square well potential (sinusoidal wave function), or a particle in a parabolic potential well (harmonic oscillator which has the ##Ae^{-x^2}## shaped wave function for its lowest energy "state") or particle in a -k/r potential (e.g. electron in a hydrogen atom).
  • · Replies 21 ·
  • · Replies 32 ·
  • · Replies 22 ·
