How to express particle momentum in [rad]
  • Thread starter Thread starter 1Keenan
    Momentum Particle
The discussion focuses on converting particle momentum from a dimensionless format to radians for use in a different simulation code. The conversion method proposed involves using the formula cos-1(|p|/py), which is already dimensionless and yields results in radians. Participants clarify that the term "rad" refers to radians, not rapidity, and emphasize the importance of understanding the definitions provided in the documentation, despite its inadequacy. The conversation highlights the need for clarity on the definition of Dp in the context of momentum calculations.
  • Understanding of particle physics and momentum concepts
  • Familiarity with the mathematical functions such as arccosine
  • Knowledge of simulation code data formats
  • Basic grasp of relativistic physics principles
  • Research the mathematical derivation of momentum in particle physics
  • Explore documentation on momentum definitions in simulation codes
  • Learn about the implications of using dimensionless quantities in physics
  • Investigate the concept of rapidity and its differences from momentum
Particle physicists, simulation developers, and anyone involved in data conversion between different scientific software formats.
1Keenan
Hi all,
I need to use the output of a simulation code in another code who accepts totally different format for data.
Now, the file I have has 5 column with positions and momenta of a certain number of particles (momenta are dimensionless - normalized to electron mass times c (light speed) )
The other code wants momenta expressed in [rad] but I don't know how to convert them...
COuld you help me?
Thanks a lot
What is a momentum expressed in rad? Is that some angle of the flight direction?
You'll have to check the documentation how that angle and other parameters are defined.
Documentation is very poor.
Anyway I think I have to evaluate it in this way:
arcosin (ModulusP/py)
There's not enough information here to be sure, but rad might mean radians, which are used as units of rapidity. http://en.wikipedia.org/wiki/Rapidity
Are you working with highly relativistic particles?
This is not rapidity.
cos-1(|p|/py) is already in rads/ That is, |p|/py is already dimensionless.
Yes, I think this is the way.
But now I have another problem: 3rd component of momenta is defined as Dp/pn (n = particle numeber).
But it is not very clear in the documentation how Dp is defined.
I think it is the average momentum - pn, but in this way I have an error message saying gamma < 1...
This is making me crazy...
  • · Replies 23 ·
  • · Replies 0 ·
