How to extract sulfur from ground water
Boiling ground water containing sulfur can produce a yellow sulfur residue, but this does not guarantee the presence of sulfur. The discussion highlights that the bad odor associated with the water is likely due to hydrogen sulfide and other sulfur compounds. Boiling aqueous solutions of sulfides in air can oxidize sulfide to elemental sulfur, but this method is insufficient for producing potable water, as hydrogen sulfide will evaporate and condense with the water.
  • Understanding of sulfur chemistry and its compounds
  • Knowledge of hydrogen sulfide properties and behavior
  • Familiarity with boiling and oxidation processes
  • Basic principles of water treatment methods
  • Research sulfur oxidation processes in aqueous solutions
  • Learn about hydrogen sulfide removal techniques in water treatment
  • Explore the chemistry of sulfur compounds and their environmental impact
  • Investigate methods for safely boiling and handling sulfur-containing water
Environmental scientists, water treatment professionals, and anyone interested in sulfur chemistry and its implications in groundwater quality.
bigtoe
Will boiling ground water that contains sulfur produce a yellow sulfur residue.
Thanks,
--Keith
It can. This doesn't mean that a yellow residue implies sulfur.
The ground water had a bad odor and I was told that it was produced from sulfur in the water. I guess the question is weather the sulfur boils away with the water and, if not, how much water would need to be boiled away to produce a noticeable amount of sulfur. My son had this question at school and the teacher was unable to answer and suggested that he investigate and report back to her. Thanks for the help. --Robert
Bad odor implies hydrogen sulfide, plus other sulfur compounds (if you're really interested, I can point you at some references on sulfur chemistry --- it ain't trivial). Boiling aqueous solutions of sulfides in air is a very mild oxidizing set of conditions that will oxidize sulfide to elemental sulfur (compared to boiling elemental sulfur in water under anaerobic conditions to get hydrogen sulfide). It's not adequate for treatment to produce potable water, nor can it be distilled too successfully, the hydrogen sulfide boils off and condenses with the water.
