How to find gravity using general relativity?
13 replies · 2K views
Christian Grey
How to find gravity of an object, like mirror,glass,tree,house etc using general relativity? Because every object exerts gravity.
What exactly do you mean by "the gravity of an object"?
Like Earth exerts a gravity on an object, objects like glass,mirror,tree etc should also exert gravity on other objects.
"Gravity" is a curvature of space-time. It isn't "exerted". I think you mean gravitational force.
Use this equation:
If the objects are stationary with respect to each other, you can use this equation:
As light is bent by the gravitation of the sun, If I am in a room, there are different objects,can path of light also be effected by those objects like that are common in everyday life, like trees, houses etc.
As light is bent by the gravitation of the sun...
Not exactly: light follows a straight path in space that is curved, which makes it appear to us to curve.
Technically yes, but for small objects that are nearby, the effect would be far too small to be measurable. It's barely measurable for the sun!
So can it be said that refraction(bending of light) of light through a glass, water etc is due to gravitation of glass,water?
No, for the reason I gave.
No, it's due to the electromagnetic properties of the glass or the water (specifically their refractive index). It has nothing to do with their gravity, which, as russ_watters pointed out, is much, much too weak to bend light measurably.
This is true in principle--in GR we would put it, as others have pointed out, that every object produces spacetime curvature. But how much spacetime curvature an object produces depends on how massive it is (actually it's more complicated than that, but for ordinary objects this approximation will do). Ordinary objects like mirrors, trees, houses, etc. have much, much, much too little mass to produce measurable spacetime curvature. It takes an object the size of a planet or star or larger to do that.
*Ahem*: https://en.wikipedia.org/wiki/Cavendish_experiment :rolleyes:
Those spheres where order 100 kg and clearly produced measurable spacetime curvature. Of course, it is not noticeable in everyday life, but it is measurable.
Yes, good point; sensitive enough equipment can detect some gravitational effects of ordinary objects. But only some of them. Detecting, for example, the bending of light passing a 100 kg sphere is far beyond our current capabilities.
However, the difference between the predictions of Newton's law of gravitation and Einstein's general relativity, for an experiment on the scale of Cavendish's, are so tiny as to be unmeasureable, as far as I know.
As others have said, the short answer is "don't bother, just use Newtonian gravity, it's good enough for that purpose".
If you want to move up a bit in scale, and ask how astronomers figure out gravity in the solar system, then to get the best accuracy you DO need to include the effects of general relativity. Furthermore, people have actually done so, because it's an important problem, so you can look up the results of their work. The details get extremely technical, but I'll mention that the output of all the work is a possibly unfamiliar object known as a metric, and it's coverd by something called the IAU 2000 resolutions.
If you want to see the end result, take a look at http://syrte.obspm.fr/IAU_resolutions/Resol-UAI.htm. It's not particularly friendly as written. I recall seeing some papers that purport to "explain" them, but unless you have more background than I think, the explanations won't be significantly less opaque than the IAU resoutions themselves.
Just to make life more interesting, I was just reading that there is some talk about "extending" the IAU metric, see http://adsabs.harvard.edu/abs/2012mgm..conf..722M for instance.
