How to Find the Basis of an Image
  • Thread starter Thread starter Abtinnn
    Basis Image
To find the basis of the image of a linear transformation, one can reduce the columns of the matrix representation to an independent spanning set using Gaussian elimination to achieve echelon form. The pivot columns in the echelon form correspond to the original columns in the matrix, which can then be selected to form the basis of the image. For example, in a transformation mapping R², the basis can be derived from the relationships between the transformed variables. The discussion also highlights that the dimension of the image can be determined by subtracting the dimension of the null space from the total dimension of the domain. Understanding these concepts is essential for mastering linear transformations and their properties.
Abtinnn
I've been reading a book on linear algebra. It talks about finding the the basis of kernel and image of a linear transformation. I understand how to find the basis of the kernel, but I don't understand how to find the basis of the image. Could someone please explain a method of doing it? Thank you!
Think about the definition of the image of a transformation ##A##: it is the set of all vectors that can be written ##A x##. If you have a matrix representation for ##A##, then any vector ##Ax## must be a linear combination of the columns of ##A##. Does that help?
jason
Likes Abtinnn
I am thinking my answer wasn't very good. This is a standard thing to do for matrices (finding basis of column space): check out pages 59-62
http://www.math.brown.edu/~treil/papers/LADW/book.pdf
Oh!
I get it now!
You're explanation actually cleared things up. And the book helped as well.
Thanks a lot for your help! :D
just reduce the columns to an independent spanning set. One way to do that is do gauss elimination via row operations until you hve echelon form. Then look where the "pivot" columns are located. Go back to the original matrix and choose the columns in those same positions and you will have a basis.
Likes Abtinnn
To take an easy example, suppose we have a linear transformation on R2 that maps (x, y) to (4x+ 2y, 2x+ y). The null space consists of all vectors that are mapped to the 0 vector: 4x+ 2y= 0 and 2x+ y= 0. In fact, 4x+ 2y= 2(2x+ y) so those are the same equation which is equivalent to y= -2x. Rather than getting the single solution, (0, 0), any vector of the form (x, y)= (x, -2x) is in the null space. The set {(1, -2)} is a basis for the one dimensional null space.
Since this operator is maps R2 to itself, and the null space has dimension 1, the image has dimension 2- 1= 1 also. But where the null space is a subspace of the domain, the image is a subspace of the range. Here, both domain and range are R2 but it is useful to make this distinction. While we can write the null space in terms of "x" and "y", to look at the image we need to write u= 4x+ 2y, v= 2x+ y and write the basis of the image in terms of u and v. Here, u= 4x+ 2y= 2(2x+ y)= 2v. A vector in the image is of the form (u, v)= (2v, v)= v(2, 1). {(2, 1)} is a basis for the image.
A slightly harder example: A linear transformation maps (x, y, z) to (x+ y+ z, y+ z, x). Now, if (x, y, z) is in the null space, we have x+ y+ z= 0, y+ z= 0, x= 0. With x= 0, both the first two equations reduce to y+ z= 0 or z= -y. Any vector in the null space is of the form (x, y, z)= (0, y, -y)= y(0, 1, -1) so {(0, 1, -1)} is a basis for the one dimensional null space.
To find a basis for the image, write u= x+ y+ z, v= y+ z, w= x. From the last equation, we an write u= w+ y+ z or u- w= y+ z= v. We have the single equation u- w= v or u= v+ w that must be satisfied for all (u, v, w) in the image. That is, any vector in the image can be written in the form (u, v, w)= (v+ w, v, w)= (v, v, 0)+ (w, 0, w)= v(1, 1, 0)+ w(1, 0, 1). {(1, 1, 0), (1, 0, 1)} is a basis for the image which is two dimensional.
Likes Abtinnn
Thanks a lot! Is this method the same as the methods mentioned by the other members? I fail to see a similarity. If this is a different method, how many ways of finding an the basis of an image are there in total?
  • · Replies 41 ·
  • · Replies 52 ·
