How to find the decay rate of processes: a→ b+c
The discussion focuses on determining the decay rate ratio of the process Δ⁺ → π⁺n and Δ⁺ → π⁰p using iso-spin states. The relevant equations involve the normalization condition |a|² + |b|² = 1, where a and b are coefficients representing the contributions of the states |π⁺n⟩ and |π⁰p⟩. The ratio of decay rates is expressed as Γ(Δ⁺ → π⁺n) / Γ(Δ⁺ → π⁰p) = |a|² / |b|². The normalization of the state is emphasized as a good practice, but not critical for calculating the decay rate ratio.
  • Understanding of iso-spin states in particle physics
  • Familiarity with decay rate calculations
  • Knowledge of normalization conditions in quantum mechanics
  • Ability to solve linear equations involving complex coefficients
  • Study the derivation of decay rates in particle physics
  • Learn about iso-spin symmetry and its applications
  • Explore normalization techniques in quantum state calculations
  • Investigate examples of decay rate ratios in particle interactions
Students and researchers in particle physics, particularly those interested in decay processes and iso-spin formalism, will benefit from this discussion.
Jamiemma1995
Show using isospin symmetry that the probabilities of the decays ∆+ → π^+n and ∆+ → π_0p are expected to be in the ratio
Γ(∆+ → π^+n)/ Γ(∆+ → π_0p)=1 /2
I unfortunately missed the classes that covered this last week due to severe health problems , I don't want anyone to solve it for me I want to learn , but my problem is I don't know how to find the decay rate of processes. Could anyone please explain the method, and give the relevant equations and then I can work it out for myself .
N.A.
As mentioned above I'm unable to begin because I don't know the relevant equations or method.
You need the following equations for the relevant iso-spin states:
|\pi^{+}n\rangle \equiv |1, 1 \rangle |\frac{1}{2} , - \frac{1}{2} \rangle = \sqrt {\frac{1}{3}} \ | \frac{3}{2} , \frac{1}{2} \rangle + \sqrt{\frac{2}{3}} \ | \frac{1}{2} , \frac{1}{2} \rangle ,|\pi^{0}p \rangle \equiv |1 , 0 \rangle |\frac{1}{2} , + \frac{1}{2} \rangle = \sqrt{\frac{2}{3}} \ |\frac{3}{2} , \frac{1}{2} \rangle - \sqrt{\frac{1}{3}} \ |\frac{1}{2} , \frac{1}{2}\rangle . Now, solve these equations for |\Delta^{+} \rangle \equiv |\frac{3}{2} , \frac{1}{2} \rangle and obtain equation of the form |\Delta^{+} \rangle = a \ |\pi^{+}n\rangle + b \ |\pi^{0}p \rangle . Make sure that |a|^{2} + |b|^{2} = 1. Now \frac{\Gamma ( \Delta^{+} \to \pi^{+} n )}{ \Gamma ( \Delta^{+} \to \pi^{0} p )} = \frac{|a|^{2}}{|b|^{2}} .
Normalising the state is generally a good advice, but not that relevant here since the sought result is a decay rate ratio.
Jamiemma1995 said:
Could anyone please explain the method, and give the relevant equations and then I can work it out for myself?
Don't you have a textbook? I'm sure it explains how to do this kind of calculation as well as giving examples.
The advice was about solving the equations correctly. Normalization is not the issue here, 10^{23}|\Delta^{+}\rangle and |\Delta^{+}\rangle lead to the same ratio. However, obtaining a^{2} + b^{2} = 1 means that his solution is definitely correct.
It is correct either way if you include the argument with the ratio. In fact, it is a very common way and important tool when solving for ratios to only care about proportionality and not the constant in front.
  • · Replies 19 ·
