How to find the equation for the maximum velocity possible
The discussion focuses on deriving the maximum velocity of an object moving in a vertical circle attached to a string, specifically at the bottom of the path where maximum tension occurs. The key equations involved are the net force equation, Fnet = Fg - Tension, and the centripetal acceleration equation, Fnet = mass x centripetal acceleration. The correct approach involves equating the forces at the bottom of the circle to find the maximum tension that the string can withstand without breaking. The conclusion emphasizes that centripetal acceleration is a result of the net force, which includes both tension and gravitational forces.
  • Understanding of centripetal acceleration and its relationship to tangential velocity
  • Familiarity with Newton's laws of motion
  • Knowledge of gravitational force and tension in a string
  • Ability to manipulate algebraic equations involving variables
  • Study the derivation of centripetal acceleration formulas
  • Explore the relationship between tension and gravitational force in circular motion
  • Learn about maximum tension conditions in physics problems
  • Investigate real-world applications of circular motion dynamics
Students studying physics, particularly those focusing on mechanics and circular motion, as well as educators looking for clear explanations of tension and velocity relationships in vertical circular motion.
brenna_s
When an object is moving in a vertical circle attached to a string, it can withhold a maximum tension at the bottom of it's path. Derive an expression for the maximum velocity the object can sustain without the string breaking. No data is given, and everything should be variables.
V minimum equals the square root of gravity x radius
Fnet equals Fg - Tension at the bottom of a vertical path
Fnet equals mass x centripetal acceleration
I attempted to use Fnet equals mass x centripetal acceleration - mg but that didn't work. I solved for v min in the previous problem, and found that it was the square root of gravity x radius, but I'm not sure how to go from that to v maximum.
Welcome to the PF.
There may be more to the problem, but as stated it seems pretty simple. It seems to only involve what happens at the bottom of the circle where the maximum velocity and the maximum string tension occur. Am I wrong about that?
You know what the centripetal acceleration is as a function of tangential velocity (and therefore the force), and you know the force on the mass is due to gravity. So just add those at the bottom of the circle and equate those to the maximum tension it takes to break the string?
Each of those is correct in itself, with appropriate choices of positive direction, but as written the two are not consistent in that regard.
At the bottom, centripetal acceleration is up but gravity is down.
That is wrong. As you wrote before, centripetal acceleration is a result of the net force. The net force is the resultant of the applied forces, tension and gravity.
Thank you both!
Likes berkeman
  • · Replies 26 ·
