How to Find the Inverse Laplace Transform for Ds + E / (s^2 +1)^2?
The problem involves finding the inverse Laplace transform of the expression (Ds + E) / (s^2 + 1)^2, which falls under the subject area of differential equations and Laplace transforms.
  • Participants discuss rewriting the expression to clarify the terms involved and question the correct form of the denominator. There are attempts to identify the next steps in finding the inverse transform, with some participants suggesting consulting Laplace transform tables and recognizing standard forms.
The discussion is ongoing, with participants exploring different interpretations of the expression and sharing insights about the methods typically used to find inverse Laplace transforms. Some guidance has been offered regarding the use of tables and recognizing forms, but no consensus on a specific approach has been reached.
There is mention of the need to know various Laplace transforms and their relationships, which may imply a prerequisite understanding of the topic. Participants express uncertainty about the next steps in the process.
kyu
Ds + E / (s^2 +1)^2
Ds / (s^2 +1) + E / (s^2 +1)
D[s/(s^2 + 1)^2] + E [1 / (s^2 + 1)^2]
You mean, I assume (Ds+ E)/(s^2+ 1)^2
That can be written as Ds/(s^2+ 1)^2+ E/(s^2+ 1)^2 but you seem to have lost the square on the denominator.
i added it.. then what should i do next? no idea how to find the inverse
Consult a table of Laplace transforms.
The standard way is to "know" a number of Laplace transforms already, plus some rules like the connection between the transforms of ##f(t)## and those of ##f'(t)##, ##\int_0^t f(\tau) \, d\tau## or ##f(t-a)## for constant ##a##--and similar general facts. Then you just try to "recognize" your ##\hat{f}(s)## among those mentioned above, and so know it inverse right away.
There are also general "inversion" formulas, but they are hardly ever used in applications to get inverses.
I suggest you struggle with this problem; it will teach you a lot, and you will be stronger for it after you are finished.
  • · Replies 31 ·
