ColdheartedGod
- 5
- 0
- Homework Statement
- Find the inverse function for a given function.
- Relevant Equations
- f(x) =(x+(x^2+1)) ^(1/3)+(x-(x^2+1))^(1/3)
The discussion revolves around finding the inverse of a complicated function, specifically involving hyperbolic trigonometric functions and algebraic manipulation. Participants are exploring various approaches to tackle the problem without providing direct solutions.
The discussion is ongoing, with various participants offering insights and alternative methods. Some have suggested specific substitutions and manipulations, while others are questioning the assumptions underlying the problem. There is no explicit consensus, but several productive lines of inquiry are being explored.
Participants note the importance of adhering to forum guidelines, particularly regarding the posting of attempts and the use of LaTeX for mathematical expressions. There are mentions of potential restrictions on the existence of inverses for certain values of the function.
Did you try to write out ##y^3## ?ColdheartedGod said:other approach
AndColdheartedGod said:I'm so sorry
Example: (right-click on formula to show math as ##\TeX## comands)BvU said:1. Learn to post using ##\LaTeX##
Thanks for the explanations!BvU said:Concerning
And
$$y = \sqrt[\leftroot{-3}\uproot{12}3]{x+\sqrt{x^2+1}} + \sqrt[\leftroot{-3}\uproot{12}3]{x-\sqrt{x^2+1}} +$$
Or simpler: your f(x) =(x+(x^2+1)) ^{(1/3)}+(x-(x^2+1))^{(1/3)} -- adorned with {} to group the (1/3) and enclosed in double $$ becomes
$$f(x) =(x+(x^2+1)) ^{1/3}+(x-(x^2+1))^{1/3} $$
when it should have been
$$f(x) =\left(x+(x^2+1)^{1/2}\right ) ^{1/3}+\left(x-(x^2+1)^{1/2}\right)^{1/3} $$
Enough showing off; back to the exercise at hand
Any light at the end of the tunnel ?
ColdheartedGod said:Thanks for the explanations!
Well, it seems that my current knowledge in trigonometry isn't good enough to carry that part so I'm now struggling to find out more about sinh functions and how to apply it in this case.![]()
It is worth trying!epenguin said:Not that anything is guaranteed before you try, but have you tried straight algebra?
In order to not get over-long formulae I would write this as
y = (A⅓ + B⅓) at first, then look at y3. (Even if, as I see, this has been disadvised.)
I'll third this recommendation. I didn't work it out, but I think I see how it goes. You get some nice simplification.epenguin said:Not that anything is guaranteed before you try, but have you tried straight algebra?
Not to mention that an inverse does not necessarily exist, in the reals, for all y. However to see into that in this case I think you need to make progress in the elaboration along the lines indicated.epenguin said:Note that inverses are not necessarily unique, but if you even get one that would be something.
epenguin said:Not to mention that an inverse does not necessarily exist, in the reals, for all y. However to see into that in this case I think you need to make progress in the elaboration along the lines indicated.
You can easily see the function f(x) itself does not exist in the reals for x between -1 and 1.
vela said:I'll third this recommendation. I didn't work it out, but I think I see how it goes. You get some nice simplification.
epenguin said:You can easily see the function f(x) itself does not exist in the reals for x between -1 and 1.
PeroK said:##f(0) = 0##
What's the problem?
It is not a good idea. Just take the cube of both sides as they are. The cube of ##y=a+b## is ##y^3=a^3+b^3+3a^2b+3ab^2 ## which can be written as ##y^3=a^3+b^3+3(ab)(a+b)##. By substitution, it becomes very simple and x can be easily isolated.WWGD said:Maybe you can follow recommendation of cubing by first leaving one of the radical expressions alone in one side before doing the cubing to avoid a mess of an expression.
You indeed get massive cancellation, but there's still a cube root left over. I get a cubic in x, lightly sprinkled with powers of y^3. I could now use cardano's formula, and maybe there's even more cancellation?ehild said:It is not a good idea. Just take the cube of both sides as they are. The cube of ##y=a+b## is ##y^3=a^3+b^3+3a^2b+3ab^2 ## which can be written as ##y^3=a^3+b^3+3(ab)(a+b)##. By substitution, it becomes very simple and x can be easily isolated.
Haven't seen much follow-up for this one. even though ##\sinh + \cosh## and ##\sinh - \cosh## yield such nice expressions ...BvU said:Other tack: try ##x = \cosh(z)##
[edit] I mean the other one: sinh !![]()
I solved using that substitution, got my answer deleted though, as per the rulesBvU said:Haven't seen much follow-up for this one. even though ##\sinh + \cosh## and ##\sinh - \cosh## yield such nice expressions ...
I saw it, but it was a bit complicated. The solution is quite simple just a polynomial of y.archaic said:I solved using that substitution, got my answer deleted though, as per the rules![]()
No need for anything complicated, like Cardano formula. If you follow the hint in #Post 20, the only cube roots remaining are in a+b, which is identical with y.willem2 said:You indeed get massive cancellation, but there's still a cube root left over. I get a cubic in x, lightly sprinkled with powers of y^3. I could now use cardano's formula, and maybe there's even more cancellation?
There is however an easier way. If you look at the original expression, you can see that it looks just like the outcome of cardano's formula. There is a depressed cubic in y with x as one of the parameters, which will have your expression as the real root. Solving this for x will be trivial.
