How to fix a quad bike handlebar starter
  • Thread starter Thread starter Siviwe Nkosana
    Bike Starter
The discussion revolves around troubleshooting a quad bike handlebar starter switch, focusing on issues related to power delivery and wiring connections. Participants explore various diagnostic approaches and wiring configurations, with an emphasis on understanding the electrical system of the Kazuma 80cc quad bike.
  • One participant notes that the starter switch makes a humming sound but does not seem to power the alternator, suggesting a potential issue with the starter relay or wiring.
  • Another participant recommends verifying the starter relay and suggests by-passing the starter solenoid to check for power reaching the starter motor, along with checking fuses and safety switches.
  • Several participants inquire about the history of the starter switch, asking if it has worked previously and about the condition of the wiring connections, particularly under electrical tape.
  • One participant describes the wiring configuration of the switch, detailing the colors and connections of the wires involved.
  • Another participant suggests searching for an electrical schematic for the Kazuma 80cc quad bike to assist in troubleshooting.
  • Multiple participants emphasize the importance of checking the battery and connections, proposing a method to test the starter directly using a known good battery.
  • There is a request for clarification on how to identify which wire supplies power to the starter switch and how the power travels through the system.
Participants express a range of diagnostic approaches and suggestions, but there is no consensus on the specific cause of the issue or a definitive solution. Multiple competing views on troubleshooting methods remain present.
Some participants mention a lack of familiarity with electrical schematics, which may limit their ability to diagnose the problem effectively. There are also unresolved questions regarding the exact wiring configuration and the condition of the components involved.
Individuals experiencing similar issues with quad bike starter systems, those interested in electrical troubleshooting, and participants looking for guidance on wiring configurations for quad bikes may find this discussion beneficial.
Siviwe Nkosana
TL;DR
Installation or a repair of quad bike handlebar starter switch
I am currently facing a problem with my quad bike handlebar starter switch.
When i am turning it on it does humming but it seems as if it is not getting the power to its alternator
Welcome!
I would verify that the stater relay is working properly.
The switch may not be the problem if you are hearing that humming sound.
If accessible, you could try by-passing the posts of the starter solenoid in order to see if electricity is reaching the starter motor.
If not, check the fuses and the safety switches.
Welcome to the PF. :smile:
Siviwe Nkosana said:
Summary:: Installation or a repair of quad bike handlebar starter switch
Did it ever work for you? If it worked, how long have you had it and it was working? If it's a new switch that you installed, what happened to the old one? Does it have a key lock? If so, why did you have to change keys?
How are the wires joined under that black electrical tape? Are they just twisted, or are they twisted and soldered?
Can you post a link to the schematic for that quad's electrical system? Which quad is it?
The bike worked completely well for me in the past few weeks
Lnewqban said:
Welcome!
The bike had been working completely well for me, in the past few weeks.
The problem with it has started by the time, there were two desoldered wires from its switch that have 3 wires
The problem with it has started by the time, there were two desoldered wires from its switch that have 3 wires connected on it.
The switch is some sort of a prong it have three poles or terminal.
First wire is Black with white stripes. The second wire is green,
And is connected in the middleThe third wire is also green and it that goes to the second switch which i guess is a pushed Starter switch, which has two poles with green wire that is coming from the prong switch and there's an outgoing wire that i guess is going to the quad system so that it can start.
The quad is model us Kazuma 80cc quad bike
As for the schematic diagram i am not so familiar with it i actually don't have it i was only taking chances in wiring it and i mma be so happy if someone can tell more on how does it system operates so that I can figure out which wire is supplying the power and so on
NB:This quad doesn't use a key
Lnewqban said:
Welcome!
I would like to know which wire is supplying the power off to the on/off switch and off to the starter pushed button
Basically i want to know how can i know i identity it?
check the battery. never assume the battery is ok. Put the quad in neutral so when the starter runs it will not rotate the gears / tires. I would get a known good battery and set it next to the quad. i would use jumper wires to hook up to a good ground o nquad to negative on battery. take a wire jumper from hot posative post on battery to the starter post. touch it to see if the starter rotates.
if it does , next try the starter solenoid. If the solenoid operates and kicks on the starter then you have a wiring problem between the solenoid and the handlebar switch. my bet is the battery and connections are bad.
Seems helpful Buddy i'll take note of your tips.
But i'mma be so proud if i can find an accurate way of wiring that handlebar switch and a bit of brief on how the power travels from the battery to switches
As @Ranger Mike said, make sure that the battery isn't the problem. If the voltage is low, it could be that the battery has a dead cell, or the alternator isn't charging it. If the batteries on my motorcycles last for four years, I consider that a success.
From what you wrote, it seems to me that what you're describing is an ignition switch. I found a wiring diagram for a Kazuma 110cc ATV, that seems close to what you're describing. In the diagram the ignition switch has a green wire that goes to ground, and a black and white wire that comes from something called Remote Control. Another wire goes to the starter relay, but the diagram doesn't indicate the color of this wire. There is also a separate starter switch with a red/yellow wire coming in and some other wire going out, with no indication of its color.
A typical handlebar starter switch would be separate from an ignition switch. A starter switch on the handlebar doesn't directly cause the starter to turn. The starter switch (or button) isn't beefy enough to handle the large current draw that the starter needs. Instead, the switch energizes a relay, which causes some heavy duty contacts to connect, and they send current to the starter solenoid. The solenoid extends the starter pinion shaft so that it contacts the ring gear on the transmission (or maybe on the engine).
Here's a link to a Kazuma 110CC quad - https://www.quadcrazy.com/atvforum/topic/7705-kazuma-falcon-110-wiring-harness-diagram/ Hope that helps.
  • · Replies 36 ·
  • · Replies 18 ·
  • · Replies 21 ·
