How to focus a shadow with the light source close to the object
  • Level: Undergrad
  • Thread starter nununo
    Shadow
3 replies · 4K views · last reply
nununo
Hi,
I have an object and I need to cast its shadow on a surface. The object is about 20cm away from the surface. When I point a light into it, if the light is too close (30cm), it casts an unfocused shadow. When I move the light away from the object, the shadow gets more and more focused. At 150cm the shadow is quite focused. But I would like the light to be very close to the object so that the shadow can be bigger. If I move the object away from the surface, its shadow gets bigger but it also gets out of focus.
I know that the light projectors in museums and theaters use lens. I also know they are ludicrously expensive. I tried using a simple lens in front of the light and somethings happened that suggest it may work with the right lens but I wouldn't know how to choose it.
Is there a cheap way to cast a focused shadow with the light close to the object?
Would using lens make it work? If so, how to choose the lens and the light?
Thanks in advance,
Nuno
Well, the "blurriness" of a shadow is caused by quantum effects around the edge of the object, light is diffracted asa wave ehen it passes within a distance comparable to its wavelength.
I doubt that is the problem here, it seems to be blurred because the light is not a point source. Diffraction effects would not diminish by moving the light source farther away.
nununo, you need to have a smaller (in size) light source. Either use a smaller light source, or you could place a piece of cardboard with a small hole in it between the light and the object. This would reduce the amount of light, which may or may not be a problem for you.
Hi Redbelly98,
Your suggestion worked. I placed a perfurated cardboard in front of the light and now, even if I put it quite close to the object, the shadow is focused. I do have less light, but I think I can manage to find a solution for that.
Thank you so much!
