How to Fourier-transform e^(-2|t|)?
The discussion revolves around determining the Fourier transforms of specific functions, particularly focusing on the function \( f(t) = e^{-2|t|} \) and its manipulation with cosine functions. The subject area includes Fourier analysis and properties of transforms.
  • Mixed
  • Participants explore the Fourier transform definition and attempt to apply it to the given functions. There are discussions about the convergence of integrals and the handling of absolute values in the context of Fourier transforms. Some participants question the setup and notation used in the original posts, while others suggest alternative approaches to the integration.
The discussion is ongoing, with participants providing insights and corrections to each other's work. Some have offered guidance on handling specific integrals and convergence issues, while others are still grappling with the correct application of the Fourier transform to the function \( f(t) = e^{-2|t|} \).
There are indications of typos and notation errors in the original attempts, which have led to confusion among participants. The complexity of integrating functions involving exponential decay and oscillatory components is also noted.
TheSodesa
Determine the Fourier-transfroms of the functions
\begin{equation*}
a) f : f(t) = H(t+3) - H(t-3) \text{ and } g : g(t) = \cos(5t) f(t)
\end{equation*}
and
\begin{equation*}
b) f : f(t) = e^{-2|t|} \text{ and } g : g(t) = \cos(3t) f(t)
\end{equation*}
The Fourier transformation definition:
\begin{equation}
\digamma\{ f(t) \}(\omega) = F(\omega) = \int_{-\infty}^{\infty} f(u)e^{-j\omega u}\,du
\end{equation}
What to do with cosines:
\begin{equation}
\digamma\{f(t)\cos(\alpha t)\}(\omega) = \frac{1}{2} F(\omega - \alpha) + \frac{1}{2}F(\omega + \alpha)
\end{equation}
I managed part a) somewhat:
\begin{align*}
\digamma\{ f(t) \}(\omega) &= \int_{-\infty}^{\infty} \left( H(t+3) - H(t-3) \right) e^{-j\omega u} \,du \\
&= \int_{-3}^{3} e^{-j\omega u} \,du = \left[ \frac{e^{-j\omega u}}{-j\omega}\right]_{-3}^{3}
= \left( \frac{e^{-j3\omega }}{-j\omega} - \frac{e^{j3\omega}}{-j\omega} \right)\\
&= \left( \frac{ e^{j3\omega}}{j\omega} - \frac{e^{-j3\omega }}{j\omega} \right) = \frac{1}{2j\omega}(e^{j3\omega } - e^{-j3\omega })\\
&= \frac{\sin(3\omega)}{\omega} = 3 sinc(3\omega)
\end{align*}
Sinc is continuous at ##\omega = 0##, so we don't need to handle that case separately.
Then, using equation (2) I wrote
\begin{align*}
\digamma\{ f(t) \cos(5t) \}(\omega) &= \frac{3}{2} sinc(3(\omega-5)) + \frac{3}{2} sinc(3(\omega+5))
\end{align*}
Part b) has me completely stumped. Since
\begin{equation}
|u|=
\begin{cases}
u &, u\geq 0\\
-u &, u < 0,
\end{cases}
\end{equation}
we write, according to equation (1):
\begin{align*}
\digamma\{ f(t) \}(\omega) &= \int_{-\infty}^{\infty} e^{-2|u|} e^{-j\omega u} \,du = \int_{-\infty}^{\infty} e^{-2|u|-j\omega u} e^{} \,du\\
&= \int_{-\infty}^{0} e^{2u-j\omega u} \,du + \int_{0}^{\infty} e^{-2u-j\omega u} \,du\\
&= \lim_{a \to \infty} \int_{-a}^{0} e^{(2-j\omega) u} \,du + \int_{0}^{a} e^{-(2+j\omega) u} \,du\\
&= \lim_{a \to \infty} \sij{-a}{0} \frac{e^{(2-j\omega) u}}{(2-j\omega)} + \sij{0}{a} \frac{e^{-(2+j\omega)u}}{-(2+j\omega)}\\
&= \lim_{a \to \infty} \left( \frac{e^0}{(2-j\omega)} - \frac{e^{-a(2-j\omega)}}{(2-j\omega)} \right)
+ \left( \frac{e^{-a(2-j\omega) }}{-(2+j\omega)} - \frac{e^0}{-(2+j\omega)} \right)\\
&= \lim_{a \to \infty} \left( \frac{1}{(2-j\omega)} - \frac{e^{-a(2-j\omega)}}{(2-j\omega)} \right)
+ \left( \frac{e^{-a(2-j\omega) }}{-(2+j\omega)} + \frac{1}{(2+j\omega)} \right) \\
&= \lim_{a \to \infty} \frac{1}{(2-j\omega)} + \frac{1}{(2+j\omega)} - \frac{e^{-a(2-j\omega) }}{(2+j\omega)} - \frac{e^{-a(2-j\omega)}}{(2-j\omega)}\\
&= \lim_{a \to \infty} \frac{(2+j\omega)}{(2+j\omega)(2-j\omega)} + \frac{(2-j\omega)}{(2+j\omega)(2-j\omega)}\\
&- \frac{(2-j\omega)e^{-a(2-j\omega) }}{(2+j\omega)(2-j\omega)} - \frac{(2+j\omega)e^{-a(2-j\omega)}}{(2+j\omega)(2-j\omega)}\\
\end{align*}
This isn't looking good. Is there a trick that I'm missing? Help would be appreciated.
\begin{equation*}
\end{equation*}
and
\begin{equation*}
\end{equation*}
\begin{equation}
\end{equation}
If you write ##\cos(3t)## in terms of ##e^{\pm 3 j t}## you have
$$\int_{-\infty}^0 e^{-j w t} e^{\pm 3 j t} e^{2t} \, dt = \frac{1}{2 - j w \pm 3 j} \left. e^{-j w t} e^{\pm 3 j t} e^{2t}\right|_{-\infty}^0,$$
which is convergent because of the exponential damping factor ##e^{2t}## when ##t \to -\infty##. Similarly for the other part.
In the ##\left[\frac{etc.}{etc.}\right]_0^a## term you omitted the u from the exponent, but that's just a typo. What I do not get is what happened to that term in the next line. How did (2+jω) turn into (2-jω)? Maybe just another typo, rectified later, but this is making it hard to follow.
haruspex said:
In the ##\left[\frac{etc.}{etc.}\right]_0^a## term you omitted the unfrom the exponent, but that's just a typo. What I do not get is what happened to that term in the next line. How did (2+jω) turn into (2-jω)? Maybe just another typo, rectified later, but this is making it hard to follow.
Yhea, I just noticed. Fixing.
Ok, so right now I have
\begin{align*}
\digamma\{f(t)\}(\omega) = \lim_{a \to \infty} \frac{(2+j\omega)e^{a(2-j\omega) }}{(2+j\omega)(2-j\omega)}
+ \frac{(2-j\omega)e^{-a(2-j\omega)}}{(2+j\omega)(2-j\omega)}
\end{align*}
Not compeltely sure what to do here. I'm trying to edit my offline LaTeX document at the same time, so mistakes are bound to be made.
\begin{align*}
\end{align*}
You still have 2-jω in both exponents.
\begin{align*}
\digamma\{f(t)\}(\omega) &= \lim_{a \to \infty} \frac{(2+j\omega)e^{a(2-j\omega) }}{(2+j\omega)(2-j\omega)}
+ \frac{(2-j\omega)e^{-a(2+j\omega)}}{(2+j\omega)(2-j\omega)}\\
&= \lim_{a \to \infty} \frac{(2+j\omega)e^{a(2-j\omega) } + (2-j\omega)e^{-a(2+j\omega)}}{(2+j\omega)(2-j\omega)}
\end{align*}
There. I think it might have been a bad idea to try and learn LaTeX proper by doing all of my coursework with it. Copy-paste can be treacherous.
It looks like I have a sum of complex conjugates in the numerator.
It's not the cosine, that scares me. What I'm ahving trouble with is ##f(t)##. I also made a few mistakes in the opening post because I'm copyin stuff from my offline LaTeX-document. They should be fixed now.
No, there's still a problem.
Look at the last two lines of your original post. In the left hand integral, you had -a in the exponent, but it becomes +a.
As Ray says, it should converge.
I would not have introduced the lim operators, though I know that is technically correct. I would have just integrated still with infinities in the bounds, and used the fact that ex+iy tends to zero as x tends to minus infinity regardless of what y does.
Alright, let me go over it once more. This might take a moment.
I got it. Just a sec, and I'll clean up my derivation.
Your ##f(t) = e^{-2|t|}## is no problem; that is why you used ##e^{2t}## for ##t < 0## and ##e^{-2t}## for ##t >0##. You get two convergent integrals. It is even faster and easier to use standard expressions for ##\int e^{at} \cos(bt) \, dt##, then use ##b = 3## and
$$ a = \begin{cases} -j\omega + 2, & t < 0\\
-j \omega - 2,& t > 0
\end{cases}
Alright, here's the complete derivation this time (hopefully) without errors:
\begin{align*}
\digamma\{ f(t) \}(\omega) &= \int_{-\infty}^{\infty} e^{-2|u|} e^{-j\omega u} \,du = \int_{-\infty}^{\infty} e^{-2|u|-j\omega u} \,du\\
&= \lim_{a \to \infty} \left[ \frac{e^{(2-j\omega) u}}{(2-j\omega)}\right]_{-a}^{0} + \left[ \frac{e^{-(2+j\omega)u}}{-(2+j\omega)}\right]_{0}^{a}\\
+ \left( \frac{e^{-a(2-j\omega) }}{-(2+j\omega)} + \frac{1}{(2+j\omega)} \right)\\
&= \lim_{a \to \infty} \frac{1}{(2-j\omega)} + \frac{1}{(2+j\omega)} - \frac{e^{-a(2-j\omega) }}{(2+j\omega)} - \frac{e^{-a(2-j\omega)}{(2-j\omega)}\\
&- \frac{(2-j\omega) \overbrace{e^{-a(2-j\omega) }}^{\text{Real coefficient goes to zero...}}}{(2+j\omega)(2-j\omega)}
- \frac{(2+j\omega)\overbrace{e^{-a(2-j\omega) }^{\text{... specifically exp(-2a)}}}{(2+j\omega)(2-j\omega)}\\
&= \frac{(2-j\omega) + (2+j\omega)}{(2+j\omega)(2-j\omega)} = \frac{4}{4 + \omega^2}
\end{align*}
Then, if we apply equation ##(2)## to the case where we multiply ##f(t)## by ##\cos(3t)##:
\begin{align*}
\digamma\{f(t)\cos(3t)\}(\omega) &= \frac{1}{2} \frac{4}{4 + \left( \omega -3 \right)^2} + \frac{1}{2} \frac{4}{4 + \left( \omega + 3 \right)^2}\\
&= \frac{2}{4 + \left( \omega -3 \right)^2} + \frac{2}{4 + \left( \omega + 3 \right)^2}\\
\end{align*}
\begin{align*}
&- \frac{(2-j\omega)\overbrace{e^{-a(2-j\omega) }}^{\text{Real coefficient goes to zero...}}}{(2+j\omega)(2-j\omega)}
- \frac{(2+j\omega)\overbrace{e^{-a(2-j\omega) }}^{\text{...specifically exp(-2a)}}}{(2+j\omega)(2-j\omega)}\\
\end{align*}
\begin{align*}
\end{align*}
Answer is correct; derivation did not render properly.
There seems to be a math processing error preventing the rendering of the biggest part of this exercise. Looking at the source code, I can't spot the error on my part.
Regradless, if it doesn't decide to resolve itself, the correct answer was
\begin{equation}
\digamma\{ f(t) \} = \frac{4}{4 + \omega^2}
\end{equation}
Thanks for the help, everyone.
Yeah, I'm wondering why that is. I tried to switch any dollar signs to double pound signs and such, but its still not rendering.
Doesn't seem to like the text imbeds
\digamma\{ f(t) \}(\omega) = ## ##\int_{-\infty}^{\infty} e^{-2|u|} e^{-j\omega u} \,du = ## ##\int_{-\infty}^{\infty} e^{-2|u|-j\omega u} \,du## ##
= \int_{-\infty}^{0} e^{2u-j\omega u} \,du + \int_{0}^{\infty} e^{-2u-j\omega u} \,du\\## ##
= \lim_{a \to \infty} \int_{-a}^{0} e^{(2-j\omega) u} \,du + \int_{0}^{a} e^{-(2+j\omega) u} \,du\\## ##
= \lim_{a \to \infty} \left[ \frac{e^{(2-j\omega) u}}{(2-j\omega)}\right]_{-a}^{0} + \left[ \frac{e^{-(2+j\omega)u}}{-(2+j\omega)}\right]_{0}^{a}\\## ##
= \lim_{a \to \infty} \left( \frac{e^0}{(2-j\omega)} - \frac{e^{-a(2-j\omega)}}{(2-j\omega)} \right)+ \left( \frac{e^{-a(2-j\omega) }}{-(2+j\omega)} - \frac{e^0}{-(2+j\omega)} \right)\\## ##
+ \left( \frac{e^{-a(2-j\omega) }}{-(2+j\omega)} + \frac{1}{(2+j\omega)} \right)\\## ##
= \lim_{a \to \infty} \frac{1}{(2-j\omega)} + \frac{1}{(2+j\omega)} - \frac{e^{-a(2-j\omega) }}{(2+j\omega)} - \frac{e^{-a(2-j\omega)}{(2-j\omega)}\\## ##
- \frac{(2+j\omega)\overbrace{e^{-a(2-j\omega) }^{\text{... specifically exp(-2a)}}}{(2+j\omega)(2-j\omega)}\\## ##
\begin{align*}
\end{align*}
