How to get an egg into a bottle
  • Thread starter Thread starter Simon Lee
    Egg
19 replies · 14K views
Simon Lee
Hi
I have a quick question for you, how do you get an egg into a bottle?
I am finishing my teaching training and am researching misconceptions in science.
One that particularly interests me is reported differently in textbooks and web sites etc.
Allow me to set the scene:
1. Hard boiled egg - shell removed.
2. Conical flask or glass bottle - neck narrower than egg.
3. Boiling water or burning candle - to go into bottle.
Could you please tell me your theories on how the egg is then 'sucked' into the bottle.
Then you can give me you researched answer.
But first I need your honest theory.
Many Kind Regards
Simon
candle uses oxgen creating a vacuum effect on the egg?
x2, the egg creates a seal, the candle uses up the oxgen which creates a lower pressure, the higher pressure outside pushes on the egg.
Using up the oxygen is not a viable answer. Think of what is happening to the air inside the flask and the function of the egg.
Creation of Vacuum Is the Answer
I've never put an egg into a bottle. If it works, it has to be by creation of a partial vacuum inside the bottle. The heat will drive out some of the air in the bottle either before the egg is placed upon it or else aftterward, if the egg-bottle seal allows one way air movement outward. Then when the air inside cools it will have less than atmospheric pressure, and whamo, the egg is pushed into the botlle by the pressurre diiference.
Ding, ding, ding! The egg sitting on the lip of the flask acts like a check valve, and as the candle heats the air, it allows the expanding air to escape. Once the candle has burned enough oxygen so that the air in the flask no longer supports combustion, the flame goes out, and the air in the flask cools, reducing the air pressure in the flask. The higher atmospheric pressure outside the flask pushes the egg into the flask.
Simon Lee said:
Hi
Assume that you are inside the bottle. :rolleyes:
Thanks everyone for your participation.
It is amazing how often people (including myself) think that burning oxygen creates a vacuum.
But as mgb pointed out, burning the candle produces CO2, that is why it is good to do the experiment with boiling water, as it heats the air inside and expands, then as it cools the air pressure inside the flask/bottle reduces below the outside levels. Then 'PLOP' in she goes.
Many Happy Regards
Simon Lee from inside the bottle.
Simon Lee said:
But as mgb pointed out, burning the candle produces CO2, that is why it is good to do the experiment with boiling water, as it heats ...
I think there might be some reactants that react with oxygen to produce some solid, and so they can create vacuum.
So, I think this is not really a physics problem.
P.S. solving this mathematically is the best way though!
Does the candle has to be inside the bottle? If not, then I'd suggest heating the air in the bottle simply by heating the bottle. If we disregard the various adverse effects of having a red-glowing bottle in contact with an egg or our skin, placing the bottle above the candle so as to heat it to as high a temperature as possible, removing the candle, placing the egg on top of the bottle while the bottle itself and the air now trapped inside cools down, should do wonders.
By having the candle outside the bottle, much higher temperatures can be achieved, and thus a much better vacuum is created during cooling.
In all fairness, everyone got the physics part of the question right, though some were more hand wavy than others. The combustion part is a chemical side note.
Thanks for the tip, I have not heard that idea before.
However the misconception is that you create a vacuum, when it comes down more to air pressure.
If anyone has a detailed explanation could they please attach it. I will be doing detailed lesson plans to dispell the myth in class.
Thanks again to all who have responded.
Simon.
Any Ideas for lesson plans to dispell the misconception?
Cheers Simon
Do the experiment as a demonstration or practical depending on the maturity of the students. Gather some ideas from the class as to why this is happening.
Then you bring in another 2 bottles, both with candles and eggs.
Do the experiment simultaneously as normal, BUT, keep one of the bottles warm, and it shouldn't suck the egg in. Then ask the class to find the difference. It should be pretty obvious to them from this second demonstration.
Make sure you experiment by yourself beforehand. Nothing cooler than stuffing up.
I've always wondered if condensation of water vapor from the burning process might have as much to do with the sucking as the thermal effect. Would you do that and let me know what happens?
Assuming a solid fuel with negligible volume.
CxHy + O2 -> H2O + CO2
You create one mole of CO2 for each mole of O2 used
The ratio of C and H in the fuel depends on the particular hydrocarbon but in longer chains it is going to approach 1 so you use a quarter as much O2 to create H2O.
This uses up O2 gas and creates H2O liquid so it does reduce the volume.
It's a space-time thing... right?
Well...
Time is just an invention to sell clocks...
And space is just a vacuum...
WHY IS IT SO?
