- 32,819
- 4,724
neurocomp2003 said:its called lab work because its assigned by a professor for their lab...whether your performing an experiment, collecting data, analyzing data, researching papers or doing simulations. This just isn't a term for physics it goes across all sciences. And from what i remember Numerical Computations are considered labwork, but it might depend on the size of your simulations...ie VR is labwork and so is astrophysics simulations(the doors that say do not enter simulations in progress)
I don't know the size of simulations that you've programmed but some simulations cannot be done on laptops.
I've written a 20-page quantum monte carlo code in C to find the band structure and calculate the activation energy of a catalyst surface used in the petroleum refining industry. It required 1 500 MHz stand-alone computer 2 1/2 days to finish a complete job. Would this be "large" enough for your consideration?
.. and I didn't have a laptop then, but I could have easily run it on my current laptop from a starbucks - I may have to LIVE there and wait for a complete run to end, but that isn't the point, is it?
As for going to starbucks to code yes you can,but only for snippets of code...when you truly want to run your simulation you will need a network or powerful computer setup like sharcnet(from cdn). Sorry the term eludes me because my brain is shutting down.
However you can also do the same thing for experimental work, not the actually implementation but the thought process and analysis. There are very few professors that i knew who wouldn't go for coffee and talk about an experiment.
I'm sure you know that "talking" about an experiment is nowhere near being the same as doing the experiment. Any experimentalist can tell you that (and one is trying to do just that right now).
Also note that some experimental labs also have programmers doing simulations in them...Ie Psych labs where there is VR and Cogsci research..as well as astrophysics labs. Maybe its a countrys terminology but in Canada we just call them labs.
Oh yeah and the term should not be confusing because the term is associated with doing work for a professor.
btw What would you call a computer science/sftware eng professors lab?
I don't really think it makes any difference in calling a physical location a "lab". However, if you equate that as doing an "experimental work", which is the term you used, then I would ask you to show where in the practice of physics such a term is widely used? If you look in either conferences, or even professional journals, that you wish to submit your work, they certainly do not consider "computer simulation" as "experimental work". If no such categories exists (in Particle Accelerator Conference, computer simulation is a category all by itself), then more often than not, computer simulation gets lumped into "theoretical" rather than "experimental" category. I should know, I've run a couple of such conferences where that was done.
If you wish to use that term, that's fine, and I'm not stopping you. I will caution you that your usage of it will create confusion and misunderstanding. If this is not something you care about, then you are more than welcome to ignore my suggestion.
Zz.
