How to graph a linear relationship between T and v of sound?
The discussion revolves around an experiment measuring the speed of sound at various temperatures, with the goal of graphing the results to identify a linear relationship between temperature and speed. The original poster expresses uncertainty about whether plotting speed against temperature will yield a straight line and considers alternative plots.
  • Participants discuss calculating speed using the formula v=d/t and plotting it against temperature. There are questions about the linearity of the relationship and the implications of the gradient. Some participants share their own plotting attempts and results, noting discrepancies with expected outcomes.
Participants are actively engaging with the problem, sharing their calculations and results. Some have offered suggestions for further investigation, such as checking the accuracy of measurements and considering the implications of their findings. There is a recognition of the need for more information to evaluate the accuracy of the experiment.
Participants note potential issues with measurement accuracy and the importance of scrutinizing results that deviate significantly from expected values. There is discussion about the temperature scale used and its impact on the results, as well as the need for further checks in the experimental setup.
Banker
I did an experiment involving the speed of sound at different temperatures. I placed two microphones at a fixed distance apart and I measured the time taken for a sound wave to travel between the two mics. I repeated this for different temperatures. I want to make a graph for my results, but I want a straight line relationship.
v=d/t , v = 331 + 0.6T
I could manually work out speed using v=d/t and plot v against the Temperature, T. However I do not know if this will give me a straight line. Or I can also plot the time against the temperature.
Extra question: in both cases, will the gradient be of any use to me?
Why hesitate ? Make the plot and post if you have questions ! :smile:
Alright, I plotted speed of sound against temperature in Kelvin. I tried to replicate the formula v = 331 +0.6T
Mine went horribly wrong. I got v = -675 + 3.07T
My telepathic capabilities are sufficient to suspect a mistake :smile: but to actually help out more information is necessary ...
I calculated the speed of sound using v=d/t where d is the fixed distance between each of the two mics and t is the time taken for the sound wave to travel between them(fast timer was used). I plotted this and their respective temperatures(in K).
So you measured 163 m/s at 0 ##^\circ##C, 224 at 20 ##^\circ##C and 286 at 40 ##^\circ##C ?
I only measured the speed at five intervals between 25 and 40 degrees celsius. The line I found is Excel's best fit line, but yes, I recorded something similar to 286 for 40 degrees.
Do you have any reason to suppose the relationship should be a straight line?
I found the equation online(v = 331.4 +0.6T). That is similar to y=mx + c, the equation of a straight line. So I am going under the assumption that that is what my results should mirror.
Banker said:
v = 331 + 0.6T
Yes, this is a common expression. But T is in ##^\circ##C, not Kelvin.
Ahh. I misinterpreted a graph I saw online and thought I had to convert into K.
I plot another graph and this time I got the result v = 164 + 3.07T
Yes, the slope doesn't change if you add a constant to the abscissa.
So how would I conclude my experiment? Because obviously my results don't fall in line with the standard. Is it scientifically accurate to call this experiment 'inaccurate'?
You don't show your observations -- at least from an earlier post I understand that the 'similar to 286 m/s' is the outcome of a calculation -- so it's hard to comment. For you it will also be hard to backtrack to find out if something went wrong.
In itself that is a very valuable learning experience: evaluate while doing the measurements so you can change things / do extra checks if results are not as expected.
Since the speed of sound is expected to be well above 300 m/s, a result below needs scrutinizing. Distance between microphones ? Time difference ? Path of the sound ?
It would be well worth it to place the microphones further apart to see if the calculated ##\Delta x\over \Delta t## is really independent of ##\Delta x##. If that isn''t the case the (much harder?) effort to vary the temperature isn't very useful.
Hard to say without further info. If your distance measurement has an accuracy of 10% and your delta time measurement also, a deviation of the "litterature value" of 355 - 286 = 70 m/s is not exceptional, but if both are supposed to be about 1% you have a problem.
I worked out the uncertainty in my gradient and y-intercept using the parallelogram method and my final answer is 164+ 3.07T, with the uncertainty in gradient being plus or minus 1.30 and the uncertainty in the y-intercept being plus or minus 44.8. So the closest I could get to the actual equation is 208.8 + 1.77T.
