How to graph velocity where there is a change in acceleration
In the discussion, participants explore how to graph velocity and acceleration when a car moves at a constant speed of 20 m/s for 100 meters before decelerating at a rate of 6 m/s². It is clarified that constant speed is indeed equal to constant velocity in this scenario. The conversation emphasizes the need to treat the motion in two segments: the first 5 seconds with constant speed and the subsequent period of deceleration. Participants discuss the correct equations for each segment, highlighting the importance of adjusting initial conditions after the first 5 seconds. Overall, the discussion focuses on understanding the relationship between speed, velocity, and acceleration in graphing motion.
Kerrie yu
The speed is a constant of 20m/s for 100m (moving on a straight line) after 100m, the car stops at a constant 6m/s/s.
*So in this case, speed is equal to velocity?
*How do you graph velocity vs time graph and acceleration vs time graph?
The problem statement tells you specifically how the acceleration is varying with time. What is your quantitative understanding of this?
But first I need to know if constant speed is equal to velocity. So if there is a constant speed of 20m/s , is it mean that the velocity is constant 20m/s ?
The problem implies that this is the case.
Chet
So for the displacement vs time graph, the line would be going up from 0 to 100 ( take 5 sec) and then from 6 sec, it starts going down by 6 because of the acceleration. 5s=100m, 6s=94m and so on?
From 0 to 5 sec., this is correct. After five seconds, it is incorrect.
What equations are you using? If you had followed the PF template, you would have written down your equations in advance, and it would have been easier to help you. Please write down your equations.
Chet
The second one? Df=...
Yes, but you would have to restart the application of the equation after the first 5 seconds, so d in the equation would be the distance relative to the location after 5 seconds, and t in the equation would be 0 at the running time of 5 seconds.
Hope this makes sense. Now, what do you get?
Chet
So we r starting new after 5sec? Df=100 ,vi=20, tf=0 ,a= -6 substitute these numbers?
Wait no,,, di =100 , df is unknown
..wait ..so since I am starting another one,, everything before 5sec doesn't matter,, so my vi is not 20m/s anymore?
You seem to be pretty confused. But, you are beginning to get the right idea.
I might be better to think of this as two separate problems:
Problem 1:
Applies between time 0 and 5 seconds
Initial distance = 0
Velocity = 20 meters/sec
Acceleration = 0
You have already solved problem 1 correctly
Problem 2
Applies after 5 seconds
Initial distance = 100
Initial velocity = 20
Acceleration = -6
You need to modify your equations a little to handle this part:
v = 20 - 6t'
d = 100 + 20t'-6(t')2/2
where t'=(t-5)
So,
v = 20 - 6(t-5)
d = 100 + 20(t-5) - 6(t-5)2/2
Do these equations make sense to you?
Chet
