How to ground EMF shielding/clothing?
  • Context: Undergrad
  • Thread starter Thread starter mcriv880
    Emf Ground
9 replies · 7K views
mcriv880
For example if a hat is lined with nickel,
silver, EMF paint, etc. , then how do you
ensure the hat is grounded? I am a little
unsure what grounding means relating to
these forms of usage as I have seen EMF protective clothing advertised as grounded.By EMF I mean sufficient for all freq with the exception of possibly Gamma Rays but not a material that produces Gamma Radiation as a result of the interaction either. What types of metals, and or materials would you use? For
example nickel, silver, gold, etc?
I guess an X Ray hat would be an example
of what I mean but other examples of hats/clothing exist capable of
blocking a wider array of frequencies. So I know they are made by the military, and privately.
You didn't read my question I'm referring to EMF shielding not sandwich foil.
Once you get into the X-Ray range it becomes extremely difficult to shield against. The higher frequency x-rays start to penetrate even thick shielding. Since UV, Visible, and much of the Infrared bands are easily blocked by normal clothing, I assume you want to block mostly Microwave and Radio waves. To my knowledge a thin metal sheet or weave would easily work, but I am no expert on EMF shielding.
Yeah but what type of metal? X Ray hats can be bought online however I'm talking about the entire spectrum, and the manufacturing of one, not the purchase.
Solid or mesh beryllium copper is about the best low cost shielding for most of the RF spectrum. Is this for “electrosmog”?
No it's not only radio frequencies. The metal, or combo of metals must block radio, infared, x-ray, etc.
Typical Conductive materials for EMF Shielding and Conductive Fabric are Nickel, Silver, Copper, Cobalt, Stainless Steel. The selection depends on the application. For example, This Nickel/Copper coated polyester mesh window screen material provides >50dB over 10 MHz-3 GHz. See the selection chart at:
http://www.lessemf.com/fabric_guide.html
Bobbywhy
When the term "grounded" is used normally that means there is a conductor connected from the object to ground. Electronics assembler workers wear ESD wrist straps that have a wire connected to "GROUND" to discharge (or not allow) any electrostatic charge buildup on their bodies which can destroy sensitive electronics.
What is the application?
X-Ray hat? Unlikely. The required material would be far too heavy to wear. Just think of the lead apron you wear at the dentist or doctors office. It ain't light.
Not going to happen. Not unless you want to wear 10 pounds of lead on your head to block the X-Rays.
