How to heat a plasma to 10^8 degrees Celsius
Germany's recent advancements in nuclear fusion involve heating plasma to temperatures exceeding 10^8 degrees Celsius using various methods. The process begins with evacuating air and impurities from the vacuum chamber, followed by charging the magnet systems to confine the plasma. Key heating techniques include ohmic heating, neutral beam heating, ion cyclotron resonance heating (ICRH), and electron cyclotron resonance heating (ECRH). Notably, the Wendelstein 7-X stellarator utilizes ECRH to achieve the necessary temperatures for fusion.
  • Nuclear fusion principles
  • Plasma physics
  • Magnetic confinement techniques
  • Heating methods for plasmas
  • Research the principles of nuclear fusion and its applications
  • Explore the mechanisms of plasma ionization and confinement
  • Study the specifics of electron cyclotron resonance heating (ECRH)
  • Investigate the differences between stellarators and tokamaks in fusion technology
Researchers, physicists, and engineers involved in nuclear fusion, plasma physics, and energy generation technologies will benefit from this discussion.
psuedoben
Recently, Germany broke headlines when they fired up their nuclear fusion reactor. As I'm sure most everyone on this forum knows this, they plan on creating fusion by heating plasma to absurd temperatures while containing it in a magnetic field. What method do they use to heat the gas and eventually the plasma to those temperatures?
Science news on Phys.org
From https://www.iter.org/mach/Tokamak
To start the process, air and impurities are first evacuated from the vacuum chamber. Next, the magnet systems that will help to confine and control the plasma are charged up and the gaseous fuel is introduced. As a powerful electrical current is run through the vessel, the gas breaks down electrically, becomes ionized (electrons are stripped from the nuclei) and forms a plasma.
As the plasma particles become energized and collide they also begin to heat up. Auxiliary heating methods help to bring the plasma to fusion temperatures (between 150 and 300 million °C). Particles "energized" to such a degree can overcome their natural electromagnetic repulsion on collision to fuse, releasing huge amounts of energy.
Wendelstein 7-X is not a tokamak, so it doesn't have a large toroidal current, so the above doesn't quite apply. W7-X is mainly heated by electron cyclotron resonance heating (ECRH) using millimeter scale electromagnetic waves from some antennas.
In stellarators and tokamaks, the standard ways of heating are:
*ohmic heating (another name for resistive heating due to the current in the plasma). This is always present in tokamaks but becomes less effective at high temperatures due to the low resistance of the plasma;
*neutral beam heating. A high energy particle beam is fired into the plasma through a side port and collides with the plasma particles
*ion cyclotron resonance heating (ICRH): antenna voltages are oscillated in synch with the cyclotron motion of heavy ions in the plasma. This generates EM waves that can be absorbed by the plasma.
*electron cyclotron resonance heating (ECRH or ECH): antenna voltages are oscillated in synch with the cyclotron motion of electrons in the plasma
  • · Replies 19 ·
  • · Replies 38 ·
  • · Replies 23 ·
